Heater core walk through. Pictures Inside! - Page 4 - JeepForum.com
post #46 of 54 Old 09-17-2014, 06:57 AM
prjohnson
Originally Posted by marcgarcia View Post
Jeeeezzzzzz, I have to do that here in a month or so. I've been putting it off and putting it off. Now winter is around the corner. It looks like a lot of time consuming work, I do appreciate the write up though.
It's really not as bad as people think. Set aside a couple days & label everything in bags.
Another tip is to remove the steering wheel from the shaft just behind the kick plate.
Honestly the hardest parts for me were separating the two box halves, then putting the box back in the Jeep (required some extra hands to get the nuts started while I held the box in place)
prjohnson is offline
post #47 of 54 Old 09-17-2014, 07:33 AM
1 Long CJ
Some will disagree on this, but my pop was an AC&R mechanic and I’ve been around that all my life. Unless you leave the evap/compressor lines disconnected several days, there is no need to evacuate the system. Residual Freon will slowly evaporate for several hours and will keep the moisture out if you keep the lines capped tightly. Add a two ounce oil charge (it comes in a small pressurized Freon can) and then add Freon back into the system to achieve proper pressure. Minimize the time you have the lines uncapped to the absolute minimum and it’s about 99% certain you won’t have moisture problems.
Anyone else try this?
Life is short. Play hard.
1979 CJ5, 1982 CJ8, 2004 WJ, 2006 LJ Rubicon
1 Long CJ is offline
post #48 of 54 Old 09-17-2014, 09:13 AM
auburnhunter
1972 CJ6
There is absolutely no reason that a vehicle should be designed like this, utterly ridiculous. I did one of these in a Dodge Dakota several years ago and it was similar. At one time I owned a 1989 Ford F250 that I had to replace heater cores in twice. It took all of 30 minutes, just a couple of screws behind the glove box.
"The problem with quotes on the internet is that you never know if they are real or not" - Abraham Lincoln
auburnhunter is offline
post #49 of 54 Old 09-17-2014, 01:07 PM
Jughead
2011 WK
NFW I'm doing that.
2003 Rubicon
2011 Laredo "X" V-6
2011 Laredo Limited Hemi
1970 Corvette Stingray 454
Jughead is offline
post #50 of 54 Old 02-17-2015, 10:49 AM
1 Long CJ
Got mine done, mostly in one day. Did not remove steering wheel.
Here's the write up I used, plus I added some of my own notes.
https://www.jeepforum.com/forum/f9/20...eater-2918601/
post #51 of 54 Old 08-07-2015, 06:00 PM
armando411
How to remove 1996 JEEP GRAND CHEROKEE CENTER DASH INFORMATION DISPLAY TRIM BEZEL
How do i remove a 1996 JEEP GRAND CHEROKEE CENTER DASH INFORMATION DISPLAY TRIM BEZEL, I want to get to the cigarette lighter and the Power Adapter Outlet to install a Dual USB Car Cigarette Lighter Socket Splitter. Thank you
armando411 is offline
post #52 of 54 Old 08-07-2015, 08:14 PM
Knuckelhead
R.I.P. Knuckelhead
Knuckelhead's Avatar
You may get better response's in this section of the forum: https://www.jeepforum.com/forum/f11/
...HTH
Knuckelhead is offline
post #53 of 54 Old 08-07-2015, 09:33 PM
mesa-jeeper
So, my heater does not blow as hot as it once did. It is no longer able to cook me out of the cab. And, that's in Phoenix were the winters are very mild. Also, I started smelling coolant every time I ran my heater last winter. Is it safe to say I'm going to have to do this core replacement?
mesa-jeeper is offline
post #54 of 54 Old 12-26-2017, 03:01 PM
KJaxTJ
Noticed the coolant puddle in passenger floorboard yesterday, so heater core has been added to my already significant to-do list.
KJaxTJ is offline
heater core , replacement
YJ Heater Core and Heater Motor Replacement?? Boston Mangler YJ Wrangler Technical Forum 11 11-29-2009 08:31 AM
Which Heater Core to Buy? WittSmall TJ Wrangler Technical Forum 2 02-23-2009 09:32 AM
*&%[email protected]###*&! Heater Core finsout TJ Wrangler Technical Forum 5 02-13-2008 03:49 PM
Dam Heater Core !!! pelos YJ Wrangler Technical Forum 3 06-19-2007 10:08 AM
heater core Jeep444 TJ Wrangler Technical Forum 13 10-28-2005 04:14 PM
