Heater Core Flush - JeepForum.com
post #1 of 6 Old 02-07-2011, 08:54 AM Thread Starter
RowJ
RowJ's Avatar
Heater Core Flush
Just flushed mine after losing my heat at 130,000 miles.
Very successful with much more heat than I would have believed possible with a rag top!
How about you?
RJ
RowJ is offline
post #2 of 6 Old 02-07-2011, 09:23 AM
ytowntj
Flush mine annually. If you have one of those prestone "T" flush kits, make sure you toss an extra cap in the Jeep. They tend to crack and split after 2-3 yrs. Wouldnt want to be left on the side of the road by a cracked cap
ytowntj is offline
post #3 of 6 Old 02-07-2011, 10:19 AM Thread Starter
RowJ
RowJ's Avatar
Thanks, that's what I'm trying to learn.... How often is flushing needed?
And does it always work or do Heater Cores sometimes fail?
Tried to do this as a Poll... but failed for some reason.
RJ
RowJ is offline
post #4 of 6 Old 02-07-2011, 10:53 AM
stuff2c
stuff2c's Avatar
I did the CLR flush and it had more **** than I ever imagined it could hold. Works like a champ now... even though i rarely ever use it (FLORIDA). Just wanted to make sure it was CLEAN!
I flush the whole thing every couple years..
Thanks to the interstate highway system... most people don't see nut'n in the USA.
stuff2c is offline
post #5 of 6 Old 02-07-2011, 11:09 AM
ytowntj
I was going the mention CLR flushing, but some on here flame for that sorta thing. It works great though
And yes, heater cores can become so clogged that flushing wont clear them. They can also leak.
ytowntj is offline
post #6 of 6 Old 02-07-2011, 11:54 AM Thread Starter
RowJ
RowJ's Avatar
Sounds like major surgury!
When I installed a new water heater in my house, plumber said "open drain once a yr for about 10 min and you'll never get major build up". That's with very hard city tap water.... so I would think, with distilled H2O/coolant, regular flush should be enough.
Trick is, I suspect to follow 'ytowntj's' example and do it annually!
RJ
RowJ is offline
heater core flush help mgaither0 TJ Wrangler Technical Forum 3 01-12-2010 07:18 PM
heater core flush, write up?? jakecarder TJ Wrangler Technical Forum 2 01-09-2009 07:50 PM
heater core reverse flush badmystur YJ Wrangler Technical Forum 8 12-21-2008 12:45 PM
Flush The Heater Core???? gtospeeding TJ Wrangler Technical Forum 3 05-28-2008 11:51 AM
Heater Core Flush Question Jeebs YJ Wrangler Technical Forum 8 02-16-2008 06:34 AM
