heater core - JeepForum.com
post #1 of 5 Old 11-09-2006, 01:54 PM Thread Starter
O2BTOM
Guest
heater core
I need to replace the heater core in my 01 sahara. How much of a pain will this be? Any tips/tricks or things I should watch out for? I have replaced heater cores in the past, but they have primarily been on older Ford pickups, and they are pretty easy...
O2BTOM is offline
post #2 of 5 Old 11-09-2006, 04:03 PM
bharris68
Gravel Truck Pilot
I'd remove the passenger seat first, that will give you more room to move/sit/look and work.
Once you find the three nuts that hold the assembly on the firewall, it's pretty easy to pull out. One is right behind the cyl head - other two are identical in size and shape and will be on either side about 12" away.
Get the seal you need, foam about 3" thick, before you start taking it out.
Drain out most of the fluid from the radiator, but expect to get some spilled when you pull the old core out.
When you have it out, clean it up, paint it generously and re-seal the halves of the assembly with RTV - make sure that the hose that goes through the firewall and dumps water, coolant, yuk is intact, not clogged and doing it's job. If it's trashed make a new one with some tubing and a right angle connector.
That's everything that I can think of
have fun!
bharris68 is offline
post #3 of 5 Old 11-09-2006, 09:00 PM
sentinal02
H2 Recovery Team Member
sentinal02's Avatar
have fun!
is this for a TJ or a YJ? he's got it in the wrong forum for the '01. moved it for ya O2.
RIP: '88 YJ 2.5L Ax-5 NP231
Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front.
92 YJ 4.0L Ax-15 231
5" springs, 1" shackle 31's or 35's depending on my mood
sentinal02 is offline
post #4 of 5 Old 11-09-2006, 09:17 PM
Thunderstrike
Thunderstrike's Avatar
2009 JK Wrangler
Dyna said just remove the battery and unscrew few things and the heater core will come out from engine side, not under the dash. There are 3 screws holding it in. Search for the posts by Dyna.
2009 JK Rubicon, 2004 TJ now gone
2019 Mustang GT 6 Spd DD
2017 Porsche 718 Cayman
Shrockworks Mid-width, Warn 9.5Ti; Skid Row Engine, LCA & Evap Skid; Rock Hard Gas Tank Skid; Warn Stainless Diff Skids, Pull-Pal, Uniden 520XL CB, Aeroforce Interceptor, Valentine 1
Ouray - TJ-8/07
Moab - TJ: 4/06, 5/08, JK: 4/09, 5/11, 4/13, 5/16, 4/17, 5/18
Rubicon - TJ-9/08
Thunderstrike is offline
post #5 of 5 Old 11-10-2006, 09:41 AM
Fritz R.
I answered in your other thread. https://www.jeepforum.com/forum/showthread.php?t=337508
Fritz
'97 TJ, 4.0L, AW-4, Flipped D300/4:1, ARB's, D44, Swayloc, RK LA, PC coils, Rancho 9000's, 33x12.5 Trxus, etc.
Fritz R. is offline
YJ Heater Core and Heater Motor Replacement?? Boston Mangler YJ Wrangler Technical Forum 11 11-29-2009 08:31 AM
heater core lilmike386 YJ Wrangler Technical Forum 2 08-24-2009 07:03 AM
Heater Core (I think) DrumBat YJ Wrangler Technical Forum 8 08-05-2009 02:18 AM
Heater Core Help stu1021 YJ Wrangler Technical Forum 4 08-03-2008 02:11 AM
Heater core. jaminb YJ Wrangler Technical Forum 5 12-04-2007 02:22 PM
