Heater Blower switch - JeepForum.com
 3Likes
  • 1 Post By bobjp
  • 1 Post By jtec
  • 1 Post By hdsport
post #1 of 6 Old 11-16-2019, 10:55 AM Thread Starter
TOMRR
TOMRR's Avatar
2006 TJ. Only have the high setting on the heater blower motor. I t is just the switch iT self or some thing else
Thanks TOMRR
TOMRR is offline
post #2 of 6 Old 11-16-2019, 11:09 AM
bobjp
There's a lot of information on this topic on the internet because this is a very common issue on TJ's.
You should start by checking the back of the switch and the connection at the resistor pack for melting/burning before replacing any parts. If that is the case your blower motor could be bad and drawing too much current. Or some say the circuit is under designed and needs relays installed. If that is not the case then you just may need to replace the resistor pack.
TOMRR likes this.
97 TJ sport.
bobjp is offline
post #3 of 6 Old 11-16-2019, 11:54 AM Thread Starter
TOMRR
TOMRR's Avatar
Thanks. Looks like it is the Resistor
TOMRR is offline
post #4 of 6 Old 11-16-2019, 12:06 PM
jtec
jtec's Avatar
2014 JK Wrangler
the resistor should have 12v all 4 wires going to controls.
which one of the 4 wires the controls ground determines speed.
TOMRR likes this.
jtec is online now
post #5 of 6 Old 11-17-2019, 03:24 AM
hdsport
Had exactly the same issue with my 2005.
New resistor solved the problem.
TOMRR likes this.
2001 Winnebago Adv 32v MH
2008 Jeep GC , 2005 TJ
US Army Vet, 8th Army,
In God We Trust
hdsport is offline
post #6 of 6 Old 11-20-2019, 01:41 PM
CGrugger
CGrugger's Avatar
I have the exact opposite problem. My high setting doesn't work. The switch is melted around that terminal. I haven't got around to getting into it yet.
Sent from my Pixel 2 XL using Tapatalk
2005 TJ X: MC 3.5" lift, 33"x12.5" tires, 1.25" Zone body lift, Curry Antirock sway bar.
CGrugger is offline
