Heat track bar or put it in a shop press? - JeepForum.com
post #1 of 16 Old 09-28-2012, 11:02 AM Thread Starter
fromme
fromme's Avatar
2015 JK Wrangler
I have a metallurgy question. If I were to heat up a spot red hot on my JKS track bar so that i can tweak it a little would that make that spot weak and brittle? Or will it make it harder like being heat treated? The issue is the JJ end on the frame is not sitting in a neutral position and at ride height is already pointed down to the passenger side. So theres not as much travel left in JJ as Id like for axle droop on that side.
I would like to tweak it a little close to the JJ so it sits closer to centered and neutral.
The other option is to put it in my shop press but im afraid without dies and such i will kink it. Ive done that on my rear track bar and it dimpled it some but thats ok back there since the rear doesnt see nearly the forces the front axle does.
2015 JKUR
fromme is offline
post #2 of 16 Old 09-28-2012, 11:11 AM
Jeepsr4me
Heat and bend, no issues. Just let it cool slow. I bent a track bar in a U shape to build a bracket for a mount and its still there with no cracks.
Jeepsr4me is offline
post #3 of 16 Old 09-28-2012, 11:31 AM
Imped
Imped's Avatar
Disassemble the JJ first so you don't melt the bushing halves.
OlllllllO
IndyORV
Imped is offline
post #4 of 16 Old 09-28-2012, 11:34 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
yea, the heat is gonna change the metal some. will it matter? probably not.
the bigger issue is the JKS track bar is tube. if you were doing this to a stock solid steel track bar, I'd say go for it...but with the tube, you're risking a kink and/or changing the structural integrity of the walls. the shop press without dies will likely kink it and make things even worse.
i think the best option is cut the JJ off and reweld it in the position you need. that means taking the JJ all apart.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #5 of 16 Old 09-28-2012, 11:46 AM Thread Starter
fromme
fromme's Avatar
2015 JK Wrangler
I don't need it bent that much, just a little nudge.
Ideally I'd cut and turn the JJ horizontally and fab up a different bracket. You guys have already went over that with me and helped out. I'd like to see if I can make it work like this before I throw in the towell. I've made some minor changes to control arm lengths and the front diff cover for clearance and I've finally got it, other than getting this thing to sit a more centered position. The JJ doesn't have to be exactly centered, just a little better than it is and I should have the travel I need.
I really should invest in a JJ tool, but in the meantime won't the old socket and bench vise trick work to disassemble and assemble one?
2015 JKUR
fromme is offline
post #6 of 16 Old 09-28-2012, 12:05 PM
afusco1222
I thought it didn't matter if the JJ was off center?
afusco1222 is offline
post #7 of 16 Old 09-28-2012, 12:40 PM
dcope17
dcope17's Avatar
^^^ it doesn't have to be centered. Just has to not bind through the entire range of axle movement. OP seems to be saying that it binds at full droop and if he moved the joint to be more neutral at ride height, it wouldn't bind anymore at droop.
Bending tubing is tough. For a front trackbar, I would only use a tube bender with the correct die. Potion B would be cut and reweld.
Life with Christ can be explained like a Jeep...
Being in the Word... grows your tire size.
Prayer... gains more ground clearance.
Fellowship... Is like having a good spotter.
The more of these you have... the easier it is to get over obstacles in your path.
dcope17 is offline
post #8 of 16 Old 09-28-2012, 12:50 PM
55willystruck
So how much droop do you have there to pull it into bind? Different mounts of some sort?
The JJ tool is certainly a valuable asset if you have bunch-I am SO glad I got mine, works great and so much easier!
But yes, the vice/socket method works as well and would be just fine for this. I'd pull the JJ out before doing any heating/welding you plan on doing there just to prevent issue with the bushing halves. It's very simple and easy to do and with only one joint to worry about, won't be any big deal at all.
You've certainly had a long battle with this. Wonder what the difference is???
Best of Luck,
Mike
55willystruck is offline
post #9 of 16 Old 09-28-2012, 01:32 PM Thread Starter
fromme
fromme's Avatar
2015 JK Wrangler
Thanks I'll try the vice/socket. No different mounts, just between the OME L shocks and the JJs offset position at ride height, it maxes it out and there's still travel left in the spring and shock. Not a huge deal but it can be better. A spring change was made from 2" soft OME to AEV 3" springs and that is certainly why the angles are all wrong now. I suppose I could try a 4"+ JKS track bar or the new Currie track bar and it would probably fit correctly. I'd like to salvage the one I have if possible.
2015 JKUR
fromme is offline
post #10 of 16 Old 09-28-2012, 02:10 PM
Barcus
Barcus's Avatar
Does anybody know off the top of their head what size sockets you use to assemble a JJ using a vise? I really need to clean and regrease my joints...sorry for the hijack!
98 TJ Currie arms-RC 2.5 coils-RC 2.0 shocks-1.25 BL-TF rear track bar-custom bumpstops-mud-scratches-gas.
Barcus is offline
post #11 of 16 Old 09-28-2012, 02:42 PM
55willystruck
The trick is to use a socket big enough to fit over the mounting flange of the ball, but small enough yet to allow you to remove the snap ring without issue.
On the small 2" joints, a 7/8" and 15/16" work OK.
It appears for the bigger 2.5" joints, a 1 1/8" and 1 1/4" should work.
While the vice method certainly works, it's FAR easier using the right JJ tool for the job. The vice kinda sucks really after using the real tool.
Best of Luck,
Mike
post #12 of 16 Old 09-28-2012, 02:47 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
I've broken 2 JKS trackbars tweaking them in a shop press. Don't do it cold.
The first thing I would do is go to the axle side where the solid end link is threaded in and tweak that up after the bend. It's solid and much more receptive to bending.
If that didn't work, I would cut and re-weld the JJ at the frame side before I tried to tweak it.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #13 of 16 Old 09-28-2012, 05:35 PM Thread Starter
fromme
fromme's Avatar
2015 JK Wrangler
Sweet, thanks for the advice. So you are saying straighten the "gold" solid end that threads in to the track bar?
Funny, because a couple weeks ago on our trail ride my friend wasn't paying attention, hit a tree hard with his passenger tire and bent that end in a U. We heated it and bent it back. Ruined the threads on it, but that's because we were unbending a bend.
This is what I'm trying to band aid if someone is looking for a visual.
2015 JKUR
fromme is offline
post #14 of 16 Old 09-28-2012, 05:55 PM
Unlimited04
looks fine.
have you actually dropped the axle to full droop, to actually find the JJ is binding?
you can't do much with the threaded end because it will hit the stock bracket under droop...thats the reason it has that bend it in.
Useful Write-Ups:
Funny:
post #15 of 16 Old 09-28-2012, 06:00 PM
Barcus
Barcus's Avatar
Best of Luck,
Mike
appreciate the info!
Barcus is offline
Heat/Floor Heat Selector Seems Jammed johnrmclean YJ Wrangler Technical Forum 9 02-13-2012 01:35 PM
Can I use a shop press to put a new axle bearing on? BigZeus TJ Wrangler Technical Forum 15 01-15-2012 11:55 PM
Hot off the press Hornsby JK Wrangler Technical Forum 23 06-12-2010 10:27 AM
Removing front track bar - is heat my only option? crqflier TJ Wrangler Technical Forum 7 06-28-2009 04:15 PM
which shop press is good enough for ax-15 bearing knl YJ Wrangler Technical Forum 5 04-26-2008 08:12 AM
