Heat soak only on specific temperature and up days - JeepForum.com
post #1 of 14 Old 03-19-2020, 06:14 PM Thread Starter
UnXplored
So today was 81 65. First day it overheated since winter. I've driven it exaxrly the same over winter and it's over heating again.
The over heat bust through the 3rd spark plug (which is stripped) then to the 02 sensor. I replaced the coil pack worn 30k spark plugs that showed overheating at the 30k with 100k Bosch double iridium.
Not sure if the whole engine block is going bad.
Any guesses? It wasn't overheating while the 30ks were fresh.
UnXplored is offline
post #2 of 14 Old 03-19-2020, 06:17 PM Thread Starter
UnXplored
Some more info it ends up pulling a P0303.
Unsure if maybe a coolant issue maybe I need to buy an aluminum radiator? But I replaced it and its still overheating. Replaced thermostat and housing.
So it sounds like a temperature sensitive issue.
Maybe the head is temperature sensitive maybe replace that? Maybe performance the exhaust system? Something has to be heat damaged and HEAT VULNERABLE maybe.
post #3 of 14 Old 03-20-2020, 04:54 AM
V8GCZJ
Might want to post what vehicle year motor etc...
V8GCZJ is offline
post #4 of 14 Old 03-20-2020, 05:02 AM
jtec
jtec's Avatar
2014 JK Wrangler
As mentioned tell us what model, year, engine, transmission.
Post all codes.
describe issue - no start, wont run, stalls, no power, hard to start when warm...etc.
jtec is offline
post #5 of 14 Old 03-20-2020, 10:55 AM Thread Starter
UnXplored
Jeep 2002 4.0L 5spd
post #6 of 14 Old 03-20-2020, 01:36 PM
mukluk
mukluk's Avatar
Normal operating temperature for the 4.0L is ~210F; what temperature are you seeing when it overheats?
Have you verified your coolant is topped off and you don't have air in the system?
Is your radiator fan working correctly?
Is anything blocking the airflow through the radiator?
Does the overheat issue occur when stopped, while driving at speed, or both?
Is the #3 spark plug stripped or is it the threads in the cylinder head that are stripped?
Are you only getting a P0303 fault code and does the same code return the very next time you drive the Jeep after clearing the code?
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #7 of 14 Old 03-20-2020, 05:51 PM Thread Starter
UnXplored
- that picture of the gauge is over what it should be.
- coolant is good. Idk about air in system no issues on cold days
- fan had a little play. I might try to install a new clutch fan I read that has helped before. Just installed a new radiator.
- driving only on hot days when its over 80 outside. Not when idle.
- yes the P0303 repeats.
The issue is I like to beat on it a little. The cold weather never over heats. Sounds like conflagration issue.
post #8 of 14 Old 03-20-2020, 05:52 PM Thread Starter
UnXplored
It's the threads in cylinder head. So it's not screwed in there properly.
post #9 of 14 Old 03-20-2020, 06:00 PM Thread Starter
UnXplored
You know I think it's the stripped cylinder head hole maybe?
post #10 of 14 Old 03-20-2020, 07:14 PM
mukluk
mukluk's Avatar
The temperature shown in your picture would still be considered normal. Overheat is when it gets to the red or at least past the white mark just to the left of the red. If your gauge isn't getting near the red, you're not overheating.
The threads in the head being stripped means you can't properly torque the sparkplug in place, which means you're losing some compression on that cylinder. That can easily be the source of your #3 cylinder misfire problem.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #11 of 14 Old 03-21-2020, 01:43 PM Thread Starter
UnXplored
Does rethreading actually work?
post #12 of 14 Old 03-21-2020, 03:02 PM
mukluk
mukluk's Avatar
To fix the stripped threads in the cylinder head you'll want to install a threaded insert. A heli-coil or better yet a time-sert would do the trick.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #13 of 14 Old 03-22-2020, 05:15 PM Thread Starter
UnXplored
Is that reliable?
post #14 of 14 Old 03-22-2020, 10:06 PM
mukluk
mukluk's Avatar
A time-sert would be my preference for fixing the existing cylinder head; it is a reliable and long term solution. The head will need to come off to do a proper job of it, so this would also be a good time to have it checked for flatness and cracks. If you're having to pay somebody else to do the cylinder head removal, inspection, machine work, threaded insert, and reinstall on the Jeep, you may be better off buying a whole replacement head.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
