has any 1 using ironman 4x4 control arms? - JeepForum.com
post #1 of 9 Old 10-15-2010, 11:53 AM Thread Starter
gattaca37
Is any 1 here using ironman 4x4 control arms. Enjoy them, hate them (pros and cons)? compare them to teraflex, JKS, currie, clayton.
He claims they r 12 threads per inch w/ jam nut, full warranty. Completely rebuildable(he says he will rebuild them cause of full warranty, if that ever happened), thanks
gattaca37 is offline
post #2 of 9 Old 10-15-2010, 12:31 PM
newbs
Jeepaholic
We put some on my friends and the build quality is nice. They are very adjustable and built to accommodate lots of lift(or cheap wheel base lengthening). Is it currie build quality no but nothing really is. I have all those brands personally except for jks and I think the ironman are a great bang for the buck.
newbs is offline
post #3 of 9 Old 10-16-2010, 05:26 PM Thread Starter
gattaca37
anybody else? anyone ever try A.R.C. fab adjustable control arms? pros and cons on those arms
post #4 of 9 Old 10-16-2010, 07:34 PM
WV-TJ
I have arc rear uppers and will say to stay clear of them. The bushing was so short in them that when the bolts were torqued down, it pinched the urethane bushings so tight that the rear of my jeep seemed almost solid.
WV-TJ is offline
post #5 of 9 Old 10-17-2010, 03:32 PM Thread Starter
gattaca37
any1 else on these two manufactures (ironman and ARC)? Anymore pros and cons is what I am asking for, thanks
post #6 of 9 Old 10-17-2010, 05:18 PM
cj777
1977 CJ7
I haven't tried them, but the warranty doesn't seem that great since it doesn't cover "Accidents, impact by rocks, trees, obstacles or other aspects of the environment." It seems like most control arm failures would be caused by "aspects of the environment." Also the exclusion for "Normal wear and tear (bushings, tie-rod ends, etc.)" would probably get him out of rebuilding the arms if needed. Full warranty info is here for referecne:
Jeep TJ Control Arms, Tie Rods, and Track Bars
That said, the price is great, and I've heard no bad reviews about the arms, just saying that the warranty wouldn't be my selling point
Wanna cracker?
'74 CJ5
'81 CJ7
'03 TJ
cj777 is offline
post #7 of 9 Old 10-17-2010, 06:55 PM
Cavitation
iron Man 4x4 uses Currie johnny joints. Looks to me that as long as there welds are good they should be as good as any.
Cavitation is offline
post #8 of 9 Old 10-17-2010, 07:41 PM
srlbotanical
srlbotanical's Avatar
I pickd up a pair of his rear uppers and I am totally happy with them. Welds are great and they are heavy.
Two Trackers 4WD Club
Wheeling in West Michigan for over 35 years.
HIGHER POWERED!!
srlbotanical is offline
post #9 of 9 Old 08-08-2011, 07:02 PM
josephmartins
Long-time Jeep Nut
josephmartins's Avatar
Old thread, but I've been researching Iron Man control arms for my WJ and I saw this particular post and had to comment about unrealistic expectations.
What sort of warranty should a consumer expect from a control arm manufacturer? Frankly, normal wear and tear is never warrantied by a company unless its owners are idiots who don't plan on being in business very long. Bushings, tie rod ends, ball joints and such are known as consumables - component products that are used up and eventually replaced. Short of a manufacturing defect that causes an obvious premature failure, don't expect insurance against normal wear and tear OR eventual failure.
And while "other aspects of the environment" is a bit vague I spoke with Andy recently when I first learned about their products and it seems he's a pretty reasonable guy. If I do something boneheaded that ruins an arm, I'm not going to expect him to give me a replacement at no cost. On the other hand, if I am driving down the highway and one of my arms has a catastrophic failure and I live to call him about it, well maybe he'll give me a replacement set for my next not-totaled Jeep. He seems to want to build solid customer relationships since his sales appear to be mostly from word of mouth and some light advertising.
Having written that, I am planning to give his fixed-length rear LCAs a try later this month and I am hoping to get him to produce a custom rear UCA for us WJ owners too.
Here's to hoping I never have to use the warranty.
Kind regards,
Joe Martins
Milford, NH
12 Wrangler Sahara JK8, 01 WJ Limited, 96 XJ Classic, 00 XJ Sport, 90 XJ Wagoneer, 97 ZJ Limited, 5.2, 98 ZJ Limited, 5.2
josephmartins is offline
IronMan Control Arms WinTech JK Wrangler Technical Forum 25 10-27-2010 09:58 AM
Combining stock control arms with Johnny Joint control arms alex_c TJ Wrangler Technical Forum 3 09-10-2010 09:55 AM
Rusty's Control Arms vs. RE Control Arms? wrangler2007 TJ Wrangler Technical Forum 26 04-12-2010 10:57 PM
Fixed control arms>Stock control arms $lick TJ Wrangler Technical Forum 12 03-21-2009 04:08 PM
regular control arms vs. heim joint control arms. lucasinpsj TJ Wrangler Technical Forum 7 10-27-2004 02:35 AM
