Hard top Wiring Harness??? - JeepForum.com
post #1 of 10 Old 08-21-2006, 07:43 AM Thread Starter
pamo
Guest
I just put a 2003 TJ hard top on my 2000 TJ.
I already have the wiring harness and washer fluid run to the back, but for some reason Jeep changed their wiring harness between 2000 and 2003.
Is there an adapter that I can get??? Or am I stuck buying an '03 harness and splicing wires...I was hoping for an adapter, it would be alot cleaner than my splicing job.
pamo is offline
post #2 of 10 Old 08-21-2006, 08:43 AM
emcee5000
emcee5000's Avatar
No adapter as far as I know. Spicing will be cheaper and easier.
emcee5000 is offline
post #3 of 10 Old 08-21-2006, 09:00 AM
ASUsax
I believe there's one other problem with this setup that you haven't considered. I believe that they changed the vent locations between the 02 and 03 model years. Your '00 is supposed to have them in the hardtop, but the '03 hardtop counts on having them in the back door. That could cause some problems...
Blue Jeep Club Member #197
'02 TJ - 33" BFG MT's's, some armor, yadda yadda. 2" BDS lift/1"BL
'94 ZJ - May it rest in pieces.
ASUsax is offline
post #4 of 10 Old 08-21-2006, 09:30 AM
VTMurphy
Guest
You can buy an adaptor for the wiring here :http://www.jeepsareus.com/Merchant2/...Code=Wrangler4
Not cheap but all the work is done for you .
Don't know how much of a problem the vents would be but you could always try to find a 03 or newer tailgate at a salvage yard that has the vents in it .
VTMurphy is offline
post #5 of 10 Old 08-21-2006, 10:25 AM Thread Starter
pamo
Guest
Thanks for the replies...I might just do it myself for $50.00.
What kind of problems would the vents cause??? I never even thought about that.
pamo is offline
post #6 of 10 Old 08-21-2006, 10:36 AM
mdm
Farm Wheeler
If you have full doors it will be hard to close the doors with the windows up.
mdm is offline
post #7 of 10 Old 08-21-2006, 10:51 AM Thread Starter
pamo
Guest
I did notice that it was kind of pressurized
Is that the only bad part about not having the vents???
pamo is offline
post #8 of 10 Old 08-21-2006, 10:55 AM
Gritz
Gritz's Avatar
The lack of venting might also affect the efficiency of the defrosting system during the winter since there is no where for the air to easily escape..... What am I saying.... it's a Jeep, not a tightly sealed Audi or BMW.
gritz
Patriot Blue 2000 Sport
2" REBB, JKS Quicker Disco's
4.0 w/5-Spd
dual tops
"It is believed dinosaurs are extinct due to a giant meteor. That's true if you want to call Chuck Norris a giant meteor."
Gritz is offline
post #9 of 10 Old 08-21-2006, 11:35 AM
ASUsax
I would think it would affect most of the A/C or heating functions, due to the inability of the air to escape.
I'd probably either look around for a '03+ tailgate, or try to find some way to 'vent' the hard top.
I have no idea how much area your vent would need to have, sorry.
ASUsax is offline
post #10 of 10 Old 08-21-2006, 12:44 PM Thread Starter
pamo
Guest
Its a jeep, like gritz said...and besides, I am sure this thing isn't airtight.
pamo is offline
Need help with Hard top Wiring harness!!!! Bill_Dunnigan TJ Wrangler Technical Forum 4 08-22-2008 09:19 PM
Hard Top Wiring -- Harness to tap into?? Jarvo2 TJ Wrangler Technical Forum 4 12-05-2006 12:56 PM
hard top wiring harness? rance23 TJ Wrangler Technical Forum 3 12-24-2005 05:50 AM
hard top wiring harness txtj79 TJ Wrangler Technical Forum 4 10-10-2005 08:17 PM
Hard Top wiring harness Signman YJ Wrangler Technical Forum 0 01-22-2002 12:57 PM
