hard top wiring harness? - JeepForum.com
post #1 of 4 Old 11-17-2005, 09:48 PM Thread Starter
rance23
Guest
I am selling my hard top tomorrow and i need to know where to un plug the harness at. i'm letting the harness got but not the switches. i know from the center roll bar forward the speaker/dome light wires run with the bundle of wires. any info would help.
rance23 is offline
post #2 of 4 Old 11-18-2005, 04:42 AM
jeffjeep1
jeffjeep1's Avatar
Unplug the harness at the hardtop. If this is a factory hardtop Jeep, the harness is integral with the rear lighting. A lot of work to remove, and you need to replace it with a softtop harness otherwise, no sound bar, no rear lights. Major work to cleanly get the harness out from between the Jeep and the gas tank. Also, the instrument panel harness is different for soft and hard top.
If you have an add on harness, start at the rear and move forwards. You even get to go into the engine compartment to the washer bottle. You will need to plug the hole in the bulkhead (firewall) and the 2nd washer pump. You will wind up going all the way to the switch panel. If you go that far, you might as well swap your switches for the buyers switch blanks. You will get to the instrument cluster too.
The add on harness will be obvious, since the factory hardtop one piece is taped together along the left rear side of the Jeep.
Also, do not what year you are selling and what year the buyer has. Some of the electrical connectors are a different size such as from 2000 to 2002, particularly at the instrument cluster. Ask me how I know.
When I bought my hardtop just recently, I wanted to use factory harness from seller, common sense set in and we stopped before the situation got ridiculous.
HTH
Jean - Wonderful wife
2003 Toyota Sequoia
2005 FA64 (aka LJ) Khaki
Heidi - Golden Retriever/Jeep Dog
jeffjeep1 is offline
post #3 of 4 Old 11-18-2005, 04:47 AM
bfr
bfr's Avatar
I would not pull the harness. just buy another from the dealer or jeepsareus
bfr is offline
post #4 of 4 Old 12-24-2005, 05:50 AM
SgtSnake
SgtSnake's Avatar
If it's a CJ, then there is a single plug that connects it to the hardtop, a 2-4 connection plug at the rear, on the drivers side. The wiring harness is standard in all CJ's and I assume the same for YJs, since I modified a YJ harness to connect to my CJ, and drove it for several months that way until I rolled it on black ice. Any other problems there, let me know.
SgtSnake Former Jeep owner with plans to buy another within the next 2 years Cousin is currently rebuilding the old jeep, but need to buy rebuilt already.
SgtSnake is offline
hard top wiring harness zackman2091 YJ Wrangler Technical Forum 58 03-15-2016 11:28 PM
Need help with Hard top Wiring harness!!!! Bill_Dunnigan TJ Wrangler Technical Forum 4 08-22-2008 09:19 PM
YJ hard top wiring harness? Foreveralout YJ Wrangler Technical Forum 1 04-19-2007 07:52 PM
Hard Top Wiring -- Harness to tap into?? Jarvo2 TJ Wrangler Technical Forum 4 12-05-2006 12:56 PM
Hard top Wiring Harness??? pamo TJ Wrangler Technical Forum 9 08-21-2006 12:44 PM
