Hard top to soft top conversion - JeepForum.com
post #1 of 3 Old 04-12-2016, 12:40 PM Thread Starter
CRD98tj
I just bought a 97 Wrangler TJ that came only with a hardtop. I want a soft top for the summer. When I purchased the Jeep I was unaware of how difficult it is to install soft top hardware and then the soft top. I was under the impression that it was an easy install and I thought I would keep a soft top for the summer and a hard top for the winter, but if installing the soft top hardware is so difficult I might sell my hard top and run the soft top year round.
I plan on purchasing the quadratop complete sailcloth with the hardware included. Does anyone have any experience with this soft top or similar from quadratec, is this a nice one compared to OEM?
Also, does anyone have any advice for installing the soft top hardware? Is it an easy install? There's basically no guides or videos for installing the hardware online.
Thank you
CRD98tj is offline
post #2 of 3 Old 04-12-2016, 01:14 PM
KrisGarner
I am the Reaper
KrisGarner's Avatar
See this thread. Unless you are dead set on a factory style top, a frameless one might be better for you. I know my SofTopper came with all hardware needed to install it and I didn't have to hunt down any stock brackets or hardware.
As far as transition from a hard top to soft, there are 2 or 3 screws on each side that attach the soft top bows to the roll bar right behind the front seats. Remove those and you should be good to swap back to a hard top. Or, they make quick releases for the bows, so you can leave the bracket on the roll bar, since they would be under the roll bar padding if you still have that in place. http://www.quadratec.com/products/11033_002.htm
KrisGarner is offline
post #3 of 3 Old 04-12-2016, 01:19 PM
beber
2005 WK
There are only 2 brackets which get mounted to roll bar which the frame attaches to. There really is not a lot of hardware and its a pretty easy instal.
I purchased the quadratec replacement top (standard version not sail cloth). IMO the fabric is top notch. However, I've been struggling with fitment issues. I just can't seem to get my top tight enough. I'm not fully sure if this is a Quadratec product issue, or an instillation issue on my end.
2005 WK Limited with 2" BB
1997 Wrangler 4 cyl, unknown 3" lift and 33"
beber is offline
soft top , soft top frame , soft top interchange
