Hard shift in cold weather - JeepForum.com
 1Likes
  • 1 Post By mukluk
post #1 of 11 Old 02-24-2020, 12:46 AM Thread Starter
tpetrovick
tpetrovick's Avatar
In the recent cold weather snap my 2000 Jeep TJ 2.5 l, 5 speed started becoming difficult to shift into 2nd gear. All others were fine. After a few miles and a warm up everything shifted fine. Is the problem low gear oil? Or something else. Thoughts? Thanks Tom
tpetrovick is offline
post #2 of 11 Old 02-24-2020, 08:24 PM
Shark_13
How old is the fluid?
Get out and explore.
Shark_13 is offline
post #3 of 11 Old 02-24-2020, 09:01 PM
TJ4Jim
My 2.5 with the same trans loves Redline MTL.
If you come to a fork in the road take it.
TJ4Jim is offline
post #4 of 11 Old 02-24-2020, 09:53 PM
mukluk
mukluk's Avatar
Cold, thick trans fluid and the synchro that tends to get the most wear... sounds fairly normal since the hard shift cleared up as the transmission warmed. It's unlikely you're low on gear oil, though that is something you can easily check and answer for yourself. You may consider letting the Jeep warm up a bit more before driving off or maybe double clutch second for the first few miles.
OlYellerTJ likes this.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #5 of 11 Old 02-25-2020, 03:27 AM Thread Starter
tpetrovick
tpetrovick's Avatar
Thanks for the feed back. I have had the Jeep a little over 2 years. God knows the age of the fluid. Warm weather I guess I should drain it and put in fresh see how that goes. I'll try the double clutch idea until then thanks again.
post #6 of 11 Old 02-25-2020, 06:42 AM
2jhanna
in your TJ, you have the AX5. Synthetic 10/30 motor oil can be used or RedLine's MT90.
I am multi-talented, I can talk and piss you off at the same time.
jhanna
denton county, tx
2jhanna is offline
post #7 of 11 Old 02-25-2020, 05:17 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
For your AX-5 go with Redline MT-90 which is a superb full synthetic lube that is ideal for the AX-5 and AX-15 transmissions. Transmissions shift better in extreme cold weather when there's a good full synthetic lube inside.
Jerry Bransford is offline
post #8 of 11 Old 02-26-2020, 03:02 AM
Jonny Jeep
Jonny Jeep's Avatar
I currently have MT-90 in my AX15 and it's good stuff. When I get around to changing my AX15's rear output seal I have Redline's recommended fluid to try. Not MT-90 or MTL as are regularly recommended on here but their 75W90NS.
Jonny Jeep is offline
post #9 of 11 Old 02-26-2020, 09:12 PM
Jerry Bransford
Administrator
You know I'm a big Redline fan but I certainly would not run any synthetic gear lube in the axles. It's well known among gear and axle-heads that the ring & pinion gears run hotter when lubed by a synthetic. That's why companies like Currie and Revolution Gear & Axle recommend strictly conventional gear lubes.
post #10 of 11 Old 02-27-2020, 01:52 AM
Jonny Jeep
Jonny Jeep's Avatar
I run dino in my axles too, Jerry. The closest the 75W90NS will get to my axles is the inside of my AX15.
Perhaps I wasn't clear enough. Redline's recommended fluid for AX gearboxes is their 75W90NS. Since they recommend it I'm going to give it a try. I can always go back to MT-90 if I don't like the feel of the shifts.
post #11 of 11 Old 02-29-2020, 06:27 PM
TJSport97
2014 WK
I've had my '97' since new and it's never been a great shift from first to second. Other gears are fine. I just learned to live with it.
Have a nice day. Gary
TJSport97 is offline
