Half doors?!?!?!?!?!?!?!?!??!?!?!? - JeepForum.com
post #1 of 22 Old 04-11-2012, 01:24 PM Thread Starter
kyle1517
Getting ready for summer and bought some half doors. not the steel ones just the vinyl ones. However they dont hit the door sensor and its keeps the lights on inside. Is there a clip for this or how can i fix it??
I have an 01 Tj.
kyle1517 is offline
post #2 of 22 Old 04-11-2012, 01:26 PM
ble10
Fuse 4 iirc
ble10 is offline
post #3 of 22 Old 04-11-2012, 01:26 PM
MAMMOTH
Wooly Member
MAMMOTH's Avatar
Pull fuse #4
2004 TJ Rubicon - 3" lift, 1" BL, Brown Dog MML with Super brackets, 33's, Warn Winch, VanCo BBK - (Thanks MisfitSeven), IronRock tierod, Ten Factory shafts.
Future upgrades - Too many to list
1999 XJ - DD with 228k
2007 JK Unlimited - The wife's ride.
MAMMOTH is offline
post #4 of 22 Old 04-11-2012, 01:27 PM
TheBoogieman
Distubed Jeepaholic
TheBoogieman's Avatar
Pull the fuse like mentioned.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
03' Rubicon/Zone 4" coils with 1" spacers up front/Rancho shocks/5.13 gears-35" MTZs/Black Magic brakes.
99' XJ /4.0L-AW4/ 5.5" lift / Rancho RS5000X shocks/33" DC Extreme country MTs. Jeep #18
TheBoogieman is offline
post #5 of 22 Old 04-11-2012, 01:27 PM Thread Starter
kyle1517
Is this the only way??
kyle1517 is offline
post #6 of 22 Old 04-11-2012, 01:28 PM
fang_x
fang_x's Avatar
yep what ble10 said, in the behind the glovebox fuse box, pull out fuse #4, its the fuse for the door chime/ interior lighting when doors are open fuse. Remove it and they wont be on anymore.
You can still turn the interior lights on from the dash switch if needed!
'98 TJ Manual -2.5" rcx long arm on 31
'99 Xj, Stock on 30"
'86 Monte Carlo 357 stroker. 450hp.
fang_x is offline
post #7 of 22 Old 04-11-2012, 01:29 PM
thirdeye
thirdeye's Avatar
yes the fuse is the best. its behind the glove box
2004 4.0L I6 TJ BUILD:
1997 2.4L I4 TJ BUILD:
https://www.jeepforum.com/forum/f22/thirdeyes-second-tj-1816002/
thirdeye is offline
post #8 of 22 Old 04-11-2012, 01:30 PM Thread Starter
kyle1517
Okay cool thanks guys!
kyle1517 is offline
post #9 of 22 Old 04-11-2012, 01:32 PM
JASON30
They sell a cap or stopper to stop the chime in quadratec . Cant remember what its called just know i rember seing it.
JASON30 is offline
post #10 of 22 Old 04-11-2012, 01:33 PM
canoeman
I also pull the fuse during the summer with running soft top and doors. Just remember that it also kill the chime that lets you know your lights are on....or at least it does on my 05 TJ
canoeman is offline
post #11 of 22 Old 04-11-2012, 01:49 PM
Just Jeff
Quadratec sells a $10 "Dome Light Switch Clip" to put over the door switch, and an actual "Dome Light Switch" (like a rocker switch) for $30.
http://www.quadratec.com/products/product_search.php?kw=door+switch&submit=Go
But I just pull fuse 4. I can still turn on the dome light with the steering wheel control if I need it.
IMPOSSIBLE JUST TAKES LONGER
http://www.tothewoods.net/
Just Jeff is offline
post #12 of 22 Old 04-11-2012, 02:37 PM
T_K
The switch would be simple to make for about 5-10 bucks from Radio Shack. I think I will make one this weekend.
T_K is offline
post #13 of 22 Old 04-11-2012, 02:41 PM
_TIM_
_TIM_'s Avatar
My dad has the switch in his LJ. Is nice to not have to worry about finding the fuse again in the winter
1998 tj|chili pepper red|
_TIM_ is offline
post #14 of 22 Old 04-11-2012, 02:57 PM
zdhutson
zdhutson's Avatar
I use the spring style clips when I take my doors off. At least I did until the fuse went bad and I didn't bother replacing it.
zdhutson is offline
post #15 of 22 Old 04-11-2012, 03:31 PM
Necko2529
Necko2529's Avatar
I pull the switch out on both sides, unplug them and toss them in the center console.
Rokmen TT, Rokmen control arms, Novak NV241 cable shifter, JKS 1.25" BL + 1" MML.
Anybody can take advice if it doesn't interfere with their plan.
RIP "Prescott 19" Prescott Fire Department
Necko2529 is offline
half door rubber seal issues (2nd sent of half doors) sail78385 TJ Wrangler Technical Forum 0 06-19-2010 01:59 PM
Half doors to full steel doors - '94 body, '88 doors xponce YJ Wrangler Technical Forum 8 02-20-2010 03:29 PM
2006 half doors vs, 2007-09 half doors crashtom Wrangler General Discussion 1 06-11-2009 02:12 PM
Half price half doors. No punt intended! Nick526 JK Wrangler Technical Forum 10 05-11-2009 09:36 AM
TJ Soft half windows on YJ half steel doors? DavesMatthew YJ Wrangler Technical Forum 5 04-17-2004 11:25 PM
