Gremlins in the lights - JeepForum.com
post #1 of 10 Old 11-26-2018, 07:29 PM Thread Starter
motovate
2003 Rubicon. Back ground - All the lights were working - then they wern't ! I was working on a little home built trailer replacing the rear lights that I managed to break both at once. I have used this trailer on this jeep and on a Nissan PU I have, Lights & wiring on the trailer were new and all of them worked on both rigs. I had just put new rear clearance lights on & was testing every thing - it all worked then I noticed LR clearance wan not working - pulled the cover took bulb out - lights still hot cleaned it and put it back in and every thing worked- then the RR clearance did the same & cleaning it did not work - it took me a minute but I saw all the running lights had quit. Turn signals worked OK - on the Jeep and trailer . Checked the jeep - turn signals work but no running lights - except the head lights work fine. The jeep was sitting static - had a fresh Optima battery just off an Optima Charger charge. While it should not matter because I operating on Battery only the Alternator has also gone wonky - charging barely 12 V. I have a new one to put on just haven't got there yet.
It sure seemed like I had popped a fuse the way it just quit on the running lights. I looked at the fuse box under the hood. There are no fuses labeled lights or even close to it. I found one of those square box thingies - what ever they are called. One 40 amp EXT Lighting. I pulled it no change - headlight worked - no running lights. Tested the fuse continuity through it just fine.
Long winded but I wanted to be clear what happened.
Is there any other fuse block or inline running light fuses or fuseable links any where else???? Any one else run into this issue??
Thanks LBM
motovate is offline
post #2 of 10 Old 11-26-2018, 07:56 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
Yes, fuse block behind the glove box. Fuse 1 is the parking/tail lights.
Rubi4MyMrs is online now
post #3 of 10 Old 11-26-2018, 09:27 PM Thread Starter
motovate
Outstanding - do I have to take the glove box out???
motovate is offline
post #4 of 10 Old 11-26-2018, 09:47 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
No, you can look from below it when it is closed. Here is a shot of mine.
Taking the box off is very easy if you want. Just slide the retaining strap off through its slot & let the box open a little further & it comes right out, maybe pull it slightly towards you.
post #5 of 10 Old 11-26-2018, 09:49 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
Looking at it more closely, it does look like the box is removed in the photo so probably a better view that way.
post #6 of 10 Old 11-26-2018, 10:07 PM Thread Starter
motovate
Great - Thanks - I found my headlamp and went out to poke around - took 1 screw out at the top of the strap and the box came right out. Pulled #1 and it was blown - problem solved- except I have bags of the full size spade fuses and nary a one of the mini spade.
Now I'll go dig up the hand book that came with the Jeep and see if there is a chart telling me what number goes where! Tomorrow I'll go to town and get a bag of minis
Really helped - Thanks LBM
motovate is offline
post #7 of 10 Old 11-27-2018, 12:35 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
If it is like my ’05, the strap slides off from the box end so you don’t have to even remove a screw but as long as you got it…
I’m not sure & can’t check mine right now but I think there is a fuse diagram on the back side of the glove box??
post #8 of 10 Old 11-27-2018, 01:21 PM Thread Starter
motovate
Thanks - Not sure if it is because it is a Rubicon and (after I found the pile of books the owners manual was buried in) my owners manual showed the hook - But my 2003 does not have a hook - it is bolted through an eyelet to the body. Easy to get to and easy out - so easy as soon as the screw was out the box fell out. I didn't see it last night because my big ole Paw was covering it but there is a diagram on the right side. Kinda one of those "if it was a Snake it would of bit me things".
Learned things - glad it wasn't a Snake
Found out there was a spare fuse - #19. Pulled it out and stuck it in #1 - Poof -it worked!! Good to go for now.
LBM
If it is like my í05, the strap slides off from the box end so you donít have to even remove a screw but as long as you got itÖ
Iím not sure & canít check mine right now but I think there is a fuse diagram on the back side of the glove box??
motovate is offline
post #9 of 10 Old 11-27-2018, 01:34 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
Mine also has the bolt but (another snake hiding) the other end of the strap slides into a slot in the box. Slide the strap to your right & catch the falling box!
You can see the hanging strap to the far right in the photo I posted…
Anyway, good to hear you got it fixed.
post #10 of 10 Old 11-27-2018, 05:48 PM Thread Starter
motovate
Nasty little Vipers!!! I actually tugged on the top and the bottom of the strap but it didn't come off and the photo's showed a hook on the top. Once you know the magic it's easy - after all these years still learning things!!!
motovate is offline
