Going through water in my Jeep? - JeepForum.com
post #1 of 21 Old 05-02-2010, 03:55 PM Thread Starter
RedHotChiliDog
RedHotChiliDog's Avatar
I already asked a question about this kinda but my Dad brought something up that I never knew. I know I should extend the breather lines past the door level (because as deep of water I go in is about that level maybe a few inches higher) but do I need to buy extensions for them or are they long enough for me to do that?
Here is what I didn't know. Apparently water can also go into the differentials too, so my question is, A. How easy is it to drain them and how long would it take and B. How often should I do this? I don't really go offroading all that often either.
Also if there is anything else I should know that would be great to tell me now!
RedHotChiliDog is offline
post #2 of 21 Old 05-02-2010, 04:05 PM
Rubikahn
Rubikahn's Avatar
The breather lines for your diffs are as follows. Front is up by the radiator. Rear is up by the gas fill tube. You should change the lube every time you're in deep enough to submerge the diffs. There have been write ups on how to extend the breather tube on the auto. Here's a write up for the diff lube change off Stu's site http://www.stu-offroad.com/misc/diff-1.htm
OME ZJ/LJ lift, 33" MT MTZ on AR-23 wheels, front and rear JKS trackbars, 1" seat risers, MORE 1" BL and MML, factory Ipod adapter. Light khaki jeep club #72
Rubikahn is offline
post #3 of 21 Old 05-02-2010, 04:17 PM
BoarderX47
Where is the water coming to on your door? Bottom of the door sill or the top by the windows? If it is just coming to the bottom of the door sill, you will not need to extend the axle breather tubes. However as said, you should change your diff fluid every time you go through high water for long periods of time.
BoarderX47 is offline
post #4 of 21 Old 05-02-2010, 04:27 PM Thread Starter
RedHotChiliDog
its at the bottom basically, there just deep water puddles, sometimes I will go through them fast, other times I take my time but they aren't very long at all, maybe 10-15 yards at the longest.
post #5 of 21 Old 05-02-2010, 04:28 PM
Douglas S.
Douglas S.'s Avatar
1991
Careful of your trans too, autos don't take well to getting water in them.
1991 Land Cruiser HDJ81
Douglas S. is offline
post #6 of 21 Old 05-02-2010, 04:29 PM Thread Starter
RedHotChiliDog
Anything I should do to protect the transmission? Or should I just avoid water alltogether....
post #7 of 21 Old 05-02-2010, 04:35 PM
2006_Sport
2006_Sport's Avatar
since he has a 2004 the breather tube will be up high enough to the point where he won't have to worry about getting water in it. The relocated the 42rle trans vent tube for that reason. The 32rh OTOH is a different story.
2006_Sport is offline
post #8 of 21 Old 05-03-2010, 06:30 PM Thread Starter
RedHotChiliDog
anyhoo, just a recap, so my breather lines should be fine for what Im going for, but I should change the oil in my differentials after every time I go in deep water for a long time or deep water in general? (I puddle jump, not cross long deep rivers haha). Also is there a way to water proof my differentials? And you guys are saying I should watch out for my auto trans. too. Is there a way to water-proof that or is it high up enough where it shouldn't matter?
Thanks for the help!
post #9 of 21 Old 05-03-2010, 06:40 PM
BoarderX47
YouTube - Jeepskool April 2010 Lower Rim Trail
Here is what I do about every month. I have never had any problem with my diffs but I make sure to change the fluid every time I go out, I have never had milky fluid. If you don't want to have to crack the diff seal every time you can pump the fluid out although cracking the cover off allows you to check for metal fillings and gear wear, I crack it every time. As for the auto trans I am not sure, I have a manual although I avoid shifting while in water at all costs unless I get stuck.
post #10 of 21 Old 05-03-2010, 07:03 PM
BYuen
BYuen's Avatar
Whenever I hit deep water I check the diff fluid when I get back home. I just remove the fill plug and dip my finger in there. If the fluid is still clean, you have nothing to worry about and don't need a change. You'll know when you get water in the diffs. The gear oil will become a whitish milky/milk shake type color. That would mean it's time for a change. Water's only gotten in my diffs because of a leaky axle shaft seal which will let water in, or when my breather tube fell off and was floating in the water sucking everything in
2001 White TJ Sport
2013 Black JKU Rubicon 10A
BYuen is offline
post #11 of 21 Old 05-03-2010, 07:05 PM
2006_Sport
2006_Sport's Avatar
You should read above where you just posted
like I said here, you'll be fine. I have done a bunch of water crossings with my auto and no problem dude.
post #12 of 21 Old 05-03-2010, 07:11 PM Thread Starter
RedHotChiliDog
alright I think I got it lol I just don't want to **** up my only ride that gets me places. And its a clean jeep on top of that so it would be a shame to **** up something major on it oh do I need to learn about jeeps sometime soon!
post #13 of 21 Old 05-24-2010, 08:32 AM Thread Starter
RedHotChiliDog
I know we already went over this but now that I'm starting to find new places to wheel, I just have one last question about this (I swear it is!): what would you say is the deepest water I can go through before stuff starts to break or require major work? Also would a air intake bag from K&N be good enough for keeping water out of my air intake as long as it's not submerged?
post #14 of 21 Old 05-24-2010, 09:26 AM
Hesher420
Hesher420's Avatar
1. You do not want to submerge you're fan or It'll suck itself into the radiator.
2. The trans. vent line ends right at the top of the trans., drivers side, by the fire wall. (I have a 42rle also) I extended mine to the top of the firewall to be extra safe.
"We are one. One society. Digitless."
"I am not a number, I am a free man!"
Hesher420 is offline
post #15 of 21 Old 07-21-2010, 05:37 PM Thread Starter
RedHotChiliDog
Well I finially took that class I was telling everyone about! But I didn't learn too much on offroading or about the vehicle in general but I still learned good stuff (it was only 7 days but two of them was taking apart a diesel down to the block and putting it back together). Anyways one thing I did learn is that apparently this is a problem on the humvees too, but when they hit water fast while the fan clutch is on, thats what causes them to break (same thing that happened to me I guess even though I wasn't going that fast). Anyways if the fan clutch is off, you generally don't have a problem.
So at what temp. does the fan clutch turn on? I figure if I only go through water when it doesn't hit that temp, I should be fine in that respect.
breather tube , checking fluid , diff fluid , differential fluid , water crossing
jeep in water.... and now water in tranny. doofusismynane TJ Wrangler Technical Forum 6 10-29-2009 06:02 PM
water getting in my jeep deryk111 TJ Wrangler Technical Forum 4 12-03-2008 04:20 PM
Run your Jeep on water! Fargo TJ Wrangler Technical Forum 25 05-31-2008 09:05 AM
How much water can get in my Jeep acsguitar TJ Wrangler Technical Forum 7 05-17-2007 05:58 AM
is water ok for my jeep!? baller88 TJ Wrangler Technical Forum 5 08-01-2004 11:55 AM
