Going from 2" to 3" - JeepForum.com
post #1 of 31 Old 01-31-2009, 11:10 AM Thread Starter
waldoo
Going from 2" to 3"
I want to go for the 3" lift. I have an 2" OME lift kit installed & want some advise on what is the best way to go. I want to get 32" tyres too.
Do I just need to change the springs or is there anything else I have to do??
I need some advise on what to do & what brands to use.
Thanx
waldoo is offline
post #2 of 31 Old 01-31-2009, 11:14 AM
TheBoogieman
The Devil's Advocate
TheBoogieman's Avatar
Put on a 1" BL and be done.No chance of vibes that way.
TheBoogieman is offline
post #3 of 31 Old 01-31-2009, 11:14 AM
Patton
You could use the OME rear track bar bracket but it will not completely center your rear axle but pretty close though. Shocks most likely will work but might be a limiting factor in droop. What front sway bar links do you have?
94 YJ 4.0/3spd dana 60/44 w/35's 9" of suspension lift
Sold-06 TJ X 4spd auto 3.73
Patton is offline
post #4 of 31 Old 01-31-2009, 11:17 AM
dogbluedrummer
Trust me....
dogbluedrummer's Avatar
Add a 1" body lift and a 1" motor mount lift. Both can be done for around $200 (total), by most anyone with basic mechanical skills, and done in one long afternoon.
Patriot Blue 2001 TJ
Everything I need to fix on the heep: ABS indicator, speed 4 on the blower fan, torn softop over driver's head, both seat release/tilt cables, missing center cap on spare, broken under hood light, wire up the CB, wiring problem with the reverse lights, broken bottle jack, leaky front and rear pinion seals, loose trackbar relocation bracket, torn drivers seat on the side, broken center console lock, lost nuts for door hinges, squeaking centering ball, loose parking brake cable, oil change and rotate the tires.
My build thread
dogbluedrummer is offline
post #5 of 31 Old 01-31-2009, 11:23 AM
95BadBoy
Thanx
^^^ Agree with what has been said above - do a BL, 1" or 1.25" whatever you like - and a BMML. Inexpensive and no need to swap out springs.
95BadBoy is offline
post #6 of 31 Old 01-31-2009, 11:31 AM
TheBoogieman
MML not needed if he wants to save money.
post #7 of 31 Old 01-31-2009, 11:07 PM Thread Starter
waldoo
I want to go for the 3" for the extra clearance & not just to fit the tyres. The 32" will fit with the current setting.
THe BL will not give me any extra groung clearance...
waldoo is offline
post #8 of 31 Old 01-31-2009, 11:19 PM
rubidriver
rubidriver's Avatar
The BL will equate to ground clearance when you are able to clear the bigger tires that you are wanting to put on...
2005 Black Rubicon - OME 933/942 - 4" Bilstein 5100 (canister up) - JKS Adj Track Bars Front/Rear - JKS Quicker Discos - 285/75/16
Originally Posted by bigj1974 View Post
your money will go farther in College Station.
rubidriver is offline
post #9 of 31 Old 02-01-2009, 05:53 AM Thread Starter
waldoo
Body lifts give tire clearance, but no ground clearance. The frame is not lifted higher so your approach and departure angles remain the same.
So if u have a 3" suspendion lift & the bigger tyres u will have even more clearance which is always a good thing
waldoo is offline
post #10 of 31 Old 02-01-2009, 05:57 AM
MudDuck99
MudDuck99's Avatar
2014 JK Wrangler
1 INCH SPACER? can pick up a set for 50 bucks
MudDuck99 is offline
post #11 of 31 Old 02-01-2009, 06:30 AM
emev0l
I'm not a fan of body lift either, and with the current 2" lift you have now you don't really need longer track bars or longer sway bar end links, but you will if you lift it to 3".
Your 2" longer shocks will be ok with 3" springs but you would be able to flex more with longer shocks.
You can do it right, or you can do it cheap.
Do you plan on going with a bigger lift later? If so I suggest buying front and rear adjustable track bars and adjustable front sway bar disconnects and adjustable rear sway bar end links. JKS makes all 4 of these and would cost between $450 and $500. These parts are adjustable from 2.5" of lift threw 6" of lift.
I don't have anything against adding coil spacers, there's just other parts you also need to add to make your jeep handle properly on the road.
emev0l is offline
post #12 of 31 Old 02-01-2009, 06:30 AM
95BadBoy
I hear you. A BL would be very helpful on your way to do a tummy tuck, and that could gain upwards of 2" of belly clearence for you. FWIW
95BadBoy is offline
post #13 of 31 Old 02-01-2009, 06:37 AM
mrfast
mrfast's Avatar
I was running a 2" bb and 1" body lift with 32x11.50 tires, and went with 3" full traction suspension lift, getting ready for 33's, anyway I really like the suspension lift, but going from 2" lift to 3" lift caused some vibrations and I ended up having to get a 1" MML which pretty well fixed that problem until I get a SYE kit.
LOL, guess what I'M saying is that extra inch of clearance was pretty expensive.
mrfast is offline
post #14 of 31 Old 02-01-2009, 06:48 AM
never monday
why not just bolt up the 32's to your current lift
never monday is offline
post #15 of 31 Old 02-01-2009, 07:37 AM
emev0l
That's what I would do, I think 2" is perfect for 32" tires, he said in an earlier post he wants his frame and gas tank 1" higher off the ground for more clearance.
emev0l is offline
Dealer says "dirty throttle body" and needs "to flush/clean the injectors"..... WheelinTJ2004 TJ Wrangler Technical Forum 18 05-17-2010 11:54 AM
Replaced Heater Core, now a "no bus" & "noFuse" on odom. WittSmall TJ Wrangler Technical Forum 12 05-11-2009 10:12 PM
mettalic "clank", "pop", "squeak" txpedro TJ Wrangler Technical Forum 2 03-21-2007 05:45 PM
Can't locate "Switched" and "unswitched" wire leads behind the glove box on 04 TJ Sparty TJ Wrangler Technical Forum 4 04-03-2004 01:24 PM
