getting beat by another TJ on highway - JeepForum.com
post #1 of 67 Old 04-22-2008, 08:25 AM Thread Starter
roadbosstx
A buddy had an identically equiped TJ to mine, 4.0, 5 speed, 33", 3.73's. His is a 98, mine is a 2000. He can run down the highway and hold 70 quite easily, of course flat ground and no wind. I can't do that and I don't like being beat. Everything on my engine is stock but he has TBS spacer and cold air induction system, but most of you guys say that doesn't do a thing for you at the rpm range that we normally run which is under 3000 rpm. My 5th gear ratio is .78 and his is .79, if the specs on this forum are correct. So, what the heck is the deal? Yes, I know that I need to re-gear and that will come in time but I think that I am comparing 'apples to apples' but I don't like mine!
roadbosstx is offline
post #2 of 67 Old 04-22-2008, 08:56 AM
Panici
(O|||||||O)
Panici's Avatar
Perhaps he was in 4th gear?
_______
|_
_|
(OlllllllO)
Panici is offline
post #3 of 67 Old 04-22-2008, 09:01 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
He cheated and threw his into 4th.Honestly,you can't hold 70mph on the highway with flat road?I've got a 98' with 3.73 gears,5 speed and 35's and I hit 90mph when I was testing out my new speedo gear.90 is freakin scarey with a lifted Jeep and 35's.
TheBoogieman is offline
post #4 of 67 Old 04-22-2008, 09:19 AM
Chuckwsu_82
My friend had a 98 with 31's and 3.73 and I had a 04 with 31's and 3.07 and I could keep up with him no problems. I am not sure the reason why, I was confused by that also
2004 Wrangler X Rubicon Express 4.5" Long Arm Tri Angulated Rear 35X14.5X15 Pitbull Rockers on 15X10 Simulock Ford 8.8 with 4.56 gears Dana 30 with ARB JKS quick Disconnect BDS rock slider AEM Brute Force cold air intake Metal Fussion Tube Fender Posion Spyder Crusher Corners
Chuckwsu_82 is offline
post #5 of 67 Old 04-22-2008, 09:43 AM
detroitmurph
I had no problem keeping up with 80-85 on the highway even with a little incline in 5th. I was running a bone stock '97 SE.
detroitmurph is offline
post #6 of 67 Old 04-22-2008, 09:47 AM
Moparkid1966
I know mine is easily capable of doing 100 mph
Moparkid1966 is offline
post #7 of 67 Old 04-22-2008, 09:48 AM
chainsaw620
With stock 3.73s and 33 muds I can keep 85 its just scary as ****
chainsaw620 is offline
post #8 of 67 Old 04-22-2008, 09:51 AM
Benny
My 04 sport 5 speed shuts down at 95, anyone else? Not trying to hijack! I have no problem holding 90 but I am on stock tires.
Benny is offline
post #9 of 67 Old 04-22-2008, 09:51 AM
Zachs
Did 95 in the rain on 30" and 3.73's...hood was lifting up and everything...scary as ****. I can't wait to do 80 with my 35's when I get the drive shaft problem settled
2000 Sahara TJ
1997 Limited ZJ
Zachs is offline
post #10 of 67 Old 04-22-2008, 09:51 AM
airframer
airframer's Avatar
i have held 80 with 3.73s and 33's, did it once and never again i like 60, very peaceful
Everything in moderation
airframer is offline
post #11 of 67 Old 04-22-2008, 10:01 AM
chainsaw620
AMEN to that!
post #12 of 67 Old 04-22-2008, 10:03 AM
BoKnows
BoKnows's Avatar
Maybe he has got a heavier foot and is just talking smack
1997 TJ White
3speed auto, RE Long Arm with ACOS...5" of lift, 35x12.50 PC XAT on 15x8 wheels, Bilstein 5100 shocks, rubicon D44 with front and rear ARBs, AA SYE, Coast CV Driveshaft, 4.10 gearing, ORO Swayloc, ARB Snorkel and K&N filter, magnaflow exhaust, Fabtech front bumper, LoD Xpedition Rear bumper, LoD Rocker Guards, hella lights, 6" Xenon flares, HULA GIRL on dash...........she makes me smile
BoKnows is offline
post #13 of 67 Old 04-22-2008, 10:05 AM
98tjsahara
When is the last time you had a tune up? Seems like something is wrong if you cant hit 70mph with that setup.
I could hit 96mph stock, now with the 31" mts it tops out at 80mph. 3.07 gears bring the suck.
Sold the 98 TJ Sahara. Buying another Jeep soon!
98tjsahara is offline
post #14 of 67 Old 04-22-2008, 10:07 AM
Wif
Wif's Avatar
Makes no sense. I know my 04 is stronger than my 01 .. just seems to pull better. They should be the same. But in your case the 2000 is stronger than the 98 and should show it
4.0L I-6 242 cu in - 1997-1999
* 181 hp @ 4,600 RPM
* 222 ft/lbs @ 2,800 RPM
* OHV
* Sequential port fuel injection
* 2 valves per cylinder
* Compression ratio = 8.80:1
4.0L I-6 242 cu in - 2000-2006
* 190 hp @ 4,600 RPM
* 235 ft/lbs @ 3,200 RPM
* OHV
* Distributor-less ignition
* Redesigned cylinder head
* Redesigned 2 piece exhaust manifold
Formally 88Jeepster
Who's in front ?
Ridin' topless again .. sweet !!
Wif is offline
post #15 of 67 Old 04-22-2008, 10:17 AM Thread Starter
roadbosstx
It makes no sense to me either. He does get his peak torque at a little lower rpm that I do. I am just scratching my bald head. I am not saying that I want to run that fast all the time but when we are driving down the road together, it just ain't right that he can beat me like that. Do any of you think that there is merit to the TBS or the cold air intake? It shouldn't have any effect at that rpm range, should it?
My JK can't keep a beat sci_teach JK Wrangler Technical Forum 14 03-19-2009 10:35 AM
beat to death blueandyellowed TJ Wrangler Technical Forum 6 05-22-2008 06:45 AM
Just beat the crap out 'em joppermann TJ Wrangler Technical Forum 3 05-11-2007 08:27 AM
i beat ya to it!!!!! asjeep TJ Wrangler Technical Forum 4 04-28-2003 05:08 PM
