Gear Pattern Help, please. - JeepForum.com
 6Likes
post #1 of 66 Old 11-23-2018, 05:23 AM Thread Starter
jeepster258
I'm in the process of setting up my gears. I'm a little confused on reading the pattern. Here are some pictures of what I have. What do you guys think what adjustment needs to be made. Backlash is at .009 on those photos.
jeepster258 is offline
post #2 of 66 Old 11-23-2018, 07:58 AM
fracturedapple
I have only set up a few diffs but what I see is your pinion depth isn't right. The pattern should be closer to the center of the teeth on the ring gear.
Sent from my SM-G900V using Tapatalk
TJnBC and fxrsliberty like this.
fracturedapple is offline
post #3 of 66 Old 11-23-2018, 08:56 AM
TJnBC
Yup what he said ^^^^ you are riding on the edges there. Get it more in the center
2006 LJR...the madness begins again
TJnBC is offline
post #4 of 66 Old 11-23-2018, 12:03 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
X3, you don't have enough pinion depth. Decrease the pinion bearing's outer shim thickness, increase the inner shim thickness.
Jerry Bransford is offline
post #5 of 66 Old 11-24-2018, 06:09 AM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
The pattern doesn't look quite symmetrical either.
Did something get bent?
Is the ring gear seated on the carrier correctly?
Joe Dillard is offline
post #6 of 66 Old 11-25-2018, 09:31 AM Thread Starter
jeepster258
Ok thanks for the help, here what I have now after about 8 trys. This ones backlash is a little too loose. I will tighten that up. What does everyone think of it now?
IMG_20181125_112232818_1543163427565.jpg   IMG_20181125_112217625_1543163442380.jpg
post #7 of 66 Old 11-25-2018, 01:34 PM Thread Starter
jeepster258
Here is a PDF of my progress
post #8 of 66 Old 11-25-2018, 01:36 PM Thread Starter
jeepster258
2
post #9 of 66 Old 11-25-2018, 03:12 PM
Boojo35
1987 YJ Wrangler
+1
If you cannot fix it with a hammer then it has to be an electrical problem.
Boojo35 is offline
post #10 of 66 Old 11-25-2018, 03:18 PM Thread Starter
jeepster258
Here is a link to a PDF of the changes I have made. https://drive.google.com/file/d/121Y...w?usp=drivesdk
post #11 of 66 Old 11-25-2018, 03:19 PM
Trevlaw
Trevlaw's Avatar
Still too shallow I think.
Id go back and try your .053" again. Put more resistance on the gears when your turning them to take the pattern, it will make it easier to read.
Keep at it, you're getting there
I want a J-Series
TJ Build:
Trevlaw is offline
post #12 of 66 Old 11-25-2018, 03:49 PM
Jerry Bransford
Administrator
X2.
post #13 of 66 Old 11-25-2018, 03:51 PM Thread Starter
jeepster258
Thanks for your opinion, it is very appreciated. I do wedge a piece of wood between the ring and housing and the flange is pretty hard to turn. Should the compound be applied thick or thin? I turn it back and forth across the paint 3 or four times.
post #14 of 66 Old 11-25-2018, 04:00 PM
Trevlaw
Trevlaw's Avatar
Thanks for your opinion it is very appreciated. I do wedge a piece of wood between the ring and housing and the flange is pretty hard to turn. Should the compound be applied thick or thin? I turn it back and forth across the paint 3 it four times.
I stuff a bunch of rags between the ring gear and the housing, might give that a shot. Your most recent pattern is pretty clear but the pic of the .053 isn't, just enough to see that the depth might be good enough. So I'd redo that a get another picture of that up. Might try in between the. 053 and .058 as well as keeping the same depth and changing the backlash to see what that does for your heel/toe position
I want a J-Series
TJ Build:
Trevlaw is offline
post #15 of 66 Old 11-25-2018, 04:10 PM Thread Starter
jeepster258
Ok sounds good. I will put it back to .053 and try to get a better visual. I guess im learning that a ton of pressure is needed to get a good reading. Thanks for sticking with me on this.
