Gear pattern check. - JeepForum.com
 3Likes
post #1 of 49 Old 07-12-2020, 01:37 PM Thread Starter
greenmachine99
greenmachine99's Avatar
Gear pattern check.
I’m regearing a dana 30 for my neighbor and just wanted an opinion on what I should do as far as pinion depth is concerned. This is at .010 backlash. To me one side looks good and the other side not so much. I’ve regeared things before but always struggle as to what I actually need to change when I don’t think it looks right. Thanks so much.
2B2F09BE-5E74-403D-BF9E-C6C7518646B5_1594582637156.jpg   AF128D70-14A8-4FF0-AE76-528CAC35735E_1594582659722.jpg
greenmachine99 is offline
post #2 of 49 Old 07-14-2020, 07:58 AM Thread Starter
greenmachine99
Bump
post #3 of 49 Old 07-14-2020, 09:30 AM
mukluk
mukluk's Avatar
Looks to me like your pinion is a little too deep.
2000 TJ SE
2005 LJ Rubicon
mukluk is online now
post #4 of 49 Old 07-14-2020, 01:24 PM
Jonny Jeep
Jonny Jeep's Avatar
I'd agree with that.
Jonny Jeep is offline
post #5 of 49 Old 07-15-2020, 10:22 AM
willis36
willis36's Avatar
A bit too deep for sure. And even though backlash is within spec, thats a touch looser than I like
willis36 is offline
post #6 of 49 Old 07-15-2020, 12:11 PM
Vinman
Search and read the Bill Vista dana 60 gear setup bible. He does a very good job of explaining how to read the gear pattern and which changes to make to correct a specific problem.
BrokeJeepJoe likes this.
Vinman is offline
post #7 of 49 Old 07-27-2020, 03:06 PM Thread Starter
greenmachine99
Added about .010 to the pinion and re ran it. This is with .006 back lash. What do you guys think?
84454945-A8F2-4498-95A5-ADCE8100C3A9_1595883863596.jpg   F0941827-0F08-4930-B60E-ED74DB444B40_1595883895792.jpg
post #8 of 49 Old 07-27-2020, 03:32 PM
mukluk
mukluk's Avatar
Still too deep. You want to remove pinion shim thickness, not add more.
2000 TJ SE
2005 LJ Rubicon
post #9 of 49 Old 07-29-2020, 03:13 PM Thread Starter
greenmachine99
Oops. I totally misinterpreted that then. So here I removed .022 so about .012 less than the initial pattern. This is with .007 backlash. To me it looks like the worst pattern yet.
62F5577D-4D35-4FAF-867F-F023CA0178C8_1596057147045.jpg   2070F314-8683-49A2-AF43-6EE3ACEAB679_1596057173631.jpg
post #10 of 49 Old 07-29-2020, 04:26 PM
Jonny Jeep
Jonny Jeep's Avatar
That is worse that the first pattern but now we know it needs to be somewhere inbetween. With the pinion looking far too shallow on the current pattern, I'd add 7 or 8 thou to the current stack so it would be closer to the original, and see what the pattern looks like.
mukluk likes this.
post #11 of 49 Old 07-30-2020, 04:03 PM Thread Starter
greenmachine99
Added .008 to the pinion and ran it again. This is with .007 back lash.
post #12 of 49 Old 07-30-2020, 04:37 PM
mukluk
mukluk's Avatar
The pattern is too shallow. Something doesn't seem right to me if there really is a difference of only .002" pinion depth between the very first and current setup.
222Doc likes this.
2000 TJ SE
2005 LJ Rubicon
post #13 of 49 Old 08-01-2020, 03:19 AM
Jonny Jeep
Jonny Jeep's Avatar
Went from 10 the wrong way to 12 the correct way and now 8 back, so this is four out from the original pattern.
Needs to be deeper again so I'd half the difference and add another two thou so it's two away from the original pattern.
post #14 of 49 Old 08-02-2020, 03:20 PM
80cj
80cj's Avatar
1980 CJ5
On your first set of patterns, you were very Slightly deep. Your back lash of .010 was a bit on the loose side. The max recommended backlash for a D30 is .009 so you were really close. Since you changed your pinon depth. I would go to what you were on your first pattern but about .002 less depth shim and that should get you there. Another thing. When you take a pattern, apply marking compound conservatively and push your ring gear back and forth into the pinion several times. The pinion preload loads the gears and usually produces a nice clear pattern. Did you notice if there was a backlash number etched on the edge of the ring gear? Some gear manufacturers do that.
80cj is offline
post #15 of 49 Old 08-05-2020, 02:39 PM Thread Starter
greenmachine99
Thanks for all the reply’s guys. I don’t get to work on this every day so sorry it’s taken so long. I added .003 to the pinion and ran it again. This is at .008 back lash. And yes, to the post above I did see a backlash. .006.
011CAFE7-4517-44AB-8400-6813E5C27C18_1596659941334.jpg   image_1596659964782.jpg
