Gauges not working 1998 Jeep Wrangler - JeepForum.com
 3Likes
  • 2 Post By mukluk
  • 1 Post By Rubi4MyMrs
post #1 of 9 Old 05-09-2019, 07:05 PM Thread Starter
Gary1223
Yesterday while driving my 1998 Jeep Wrangler the speedometer, oil pressure, and temperature gauge stopped working. I turn my vehicle off turn it back on and they begin to work again. Later in the day it stopped again and have not worked today. My tac, fuel and battery gauges work fine. I have checked all the fuses, the ground on the engine block, both side speakers ground wires and under dash ground wire and everything is grounded. I pulled off the cluster checked all the pins nothing was broken everything was clean.. Any help would be appreciated. Thanks for everybody’s time
Gary1223 is offline
post #2 of 9 Old 05-09-2019, 07:26 PM
mukluk
mukluk's Avatar
Does the cluster pass a self test?
  • With the ignition off, press and hold the odometer trip reset button.
  • Switch the ignition on while still holding the trip reset button, then release the button after about two or three seconds.
  • The cluster will run a self test procedure where each gauge will move to specific values, lamps test, and the odometer display will count through (see attached).
Strelnikov and Shark_13 like this.
2000 TJ SE
2005 LJ Rubicon
mukluk is online now
post #3 of 9 Old 05-10-2019, 04:56 PM Thread Starter
Gary1223
Thank you. I tried it. The speedometer, oil, and temp did not move at all. On the left side the tac, fuel, and battery all moved. Thanks for your input. Any recommendations ?
Gary1223 is offline
post #4 of 9 Old 05-10-2019, 07:16 PM
mukluk
mukluk's Avatar
Most likely your instrument cluster is bad. To be thorough, make sure you have good continuity to ground at the green cluster plug pin 9 (BK/LG wire) and at pin 6 (BK/LG wire) of the grey plug. Also check for constant battery voltage at pin 9 (PK/WT) and ignition switched battery power at pin 8 (DB/WT) of the grey plug.
2000 TJ SE
2005 LJ Rubicon
post #5 of 9 Old 05-10-2019, 07:30 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
It does sound like the cluster & may “just” be a burnt out spot on the printed circuit board. It would be worth pulling the cluster & carefully inspecting the board. If you see a bad spot you might be able to fix it or have someone with that kind of experience do it.
Here is an example, different problem but caused by a bad spot on the board that he fixed.
https://www.jeepforum.com/forum/f9/ho...issue-2913730/
mukluk likes this.
Rubi4MyMrs is online now
post #6 of 9 Old 05-21-2019, 05:23 PM Thread Starter
Gary1223
Thanks for everybody’s input. I ordered a used one online and received it today. I hooked it up and everything works perfect. So it was the cluster that went bad. Thanks again!
Gary1223 is offline
post #7 of 9 Old 05-21-2019, 05:47 PM
mukluk
mukluk's Avatar
Appreciate the follow up, glad you got it fixed.
2000 TJ SE
2005 LJ Rubicon
post #8 of 9 Old 05-21-2019, 06:58 PM
2jhanna
Gary, isn't your odometer mileage wrong with the replacement cluster?
Just wondering !
Also, did you examine the circuit board of the old cluster for a burned trace?
I am multi-talented, I can talk and piss you off at the same time.
jhanna
denton county, tx
2jhanna is offline
post #9 of 9 Old 05-24-2019, 07:13 PM Thread Starter
Gary1223
Yes, I can not find anything burnt or out of place. Thanks again for all your help.
Gary1223 is offline
My goal is to get 25+ mpg from my 99 XJ with 30 x 9.5 R15 ATs Charley3 XJ Cherokee Technical Forum 3856 07-28-2019 09:18 AM
Trials & Tribulations RubiconFreedom Wrangler General Discussion 7 05-03-2019 10:12 AM
2012 Jeep Wrangler Unlimited Rubicon BigD97TJ Jeeps For Sale 2 05-24-2018 04:26 PM
1998 jeep wrangler bolts for power steering gear box Rickyminton Florida Jeep Forum 1 03-10-2018 11:28 AM
