Gauge cluster mystery- 2004 LJ 42RLE trans - JeepForum.com
post #1 of 4 Old 07-19-2010, 05:58 PM Thread Starter
jlax2485
jlax2485's Avatar
Ok guys...I have sort of a mystery on my hands. Last week, my gauges started shutting off and coming back on during driving. Hitting the gauge cluster always seemed to be able to bring them back on, which led me to believe there was a loose connection back there. I took the cluster out of the dash, cleaned the terminals and plugs with rubbing alcohol, and then re-connected. It seemed to work briefly, until a day later, when my gauges started acting up again.
Last night, I got the error code P-1698 (No CCD/J1850 messages received from the electronic transmission control module (EATX) or the Aisin transmission controller). Okay, I thought...I'll just check to see if there is a loose connection with the TCM. The connection was fine, and my jeep ran like normal and the trans shifted like normal. (I was told that the tranny wouldnt shift out of 1st gear if the ECM was throwing this code).
Long-story short...I did some research and found that other chrysler vehicles were notorious for throwing this code; as the solder joints on the cluster circuit board will crack and cause a bad connection.
Before I rip this thing apart and check the solder joints, potentially ruining a 300-dollar gauge cluster, is there anything else that could be causing this error code? My jeep starts and runs just fine. Sometimes it wont unless I hit the cluster while starting it up...but it shifts and runs great.
Does anyone have any advice or words of wisdom that could help me out? Thanks guys
jlax2485 is offline
post #2 of 4 Old 07-19-2010, 07:36 PM
LJameson
LJameson's Avatar
I'd check all of your grounds first before tearing into that thing.
1990 YJ
1976 CJ7
LJameson is offline
post #3 of 4 Old 07-19-2010, 07:50 PM
Nicho
Nicho's Avatar
Nicho is offline
post #4 of 4 Old 07-19-2010, 09:21 PM Thread Starter
jlax2485
jlax2485's Avatar
Hey, thanks nick. I'm going to give jerry's idea a try and see how flattening the pins works.
jlax2485 is offline
p1698 , gauge cluster , solder joints , lj , wrangler , TJ
Trans Temp ? 42RLE GREASEMONKEY TJ Wrangler Technical Forum 21 05-05-2011 10:08 PM
42RLE temp gauge malfunction jeep2008 TJ Wrangler Technical Forum 26 04-08-2010 04:09 PM
42rle trans lines #686 Sahara TJ Wrangler Technical Forum 4 01-31-2010 04:39 PM
42rle temp gauge 04TJSport TJ Wrangler Technical Forum 74 11-08-2009 11:16 AM
can i swap in a 42RLE from a 2004 into my 97 TJ?? 97casteeltj TJ Wrangler Technical Forum 3 12-15-2008 09:14 PM
