Gas tank overflow when filling up - JeepForum.com
post #1 of 14 Old 06-01-2019, 11:07 AM Thread Starter
tangolima
Anyone else have this problem? The guy pumping my gas said he sometimes sees this happening with Jeeps. When I'm filling up my gas tank, it tends to overflow/spill out when reaching capacity. Is it because of the high speed pumps? Sometimes I can mitigate it by slowing the speed of the gas coming from the nozzle when I'm approaching capacity, but sometimes it's hard to gauge.
tangolima is offline
post #2 of 14 Old 06-01-2019, 11:17 AM
jtec
jtec's Avatar
2014 JK Wrangler
ask yur local friendly jeep dealer about TSB #14-001-09 REV. A.
Sorry cant get details today
jtec is offline
post #3 of 14 Old 06-01-2019, 01:44 PM
mukluk
mukluk's Avatar
Common problem with the late TJs.
https://www.jeepforum.com/forum/f9/g.../#post40275981
2000 TJ SE
2005 LJ Rubicon
mukluk is online now
post #4 of 14 Old 06-01-2019, 01:52 PM
JEK3
JEK3's Avatar
Originally Posted by mukluk View Post
Yep, happened to mine also. One fix, which I did initially, is replacing the filler hose with a GM one that has a flapper valve in it. This lasted me many years, but eventually the hose buckled and restricted the flow coming in. The permanent fix involves dropping the tank, pulling out the rollover valve, and shaving down a few plastic nubs. I did this a couple months ago, and it really wasn't difficult. Hardest part was getting the gasoline smell out of my hair (I skipped the step where you depressurize the fuel line).
JEK3 is offline
post #5 of 14 Old 06-02-2019, 06:20 AM
williambmac
williambmac's Avatar
TSB #14-001-09 basically has you do a few tests with the evap system to rule out a blockage in either the evap hose or the cannister. Once the evap system is ruled out, fuel tank replacement is required.
Basically the roll over valve in the tank fails. a replacement tank is around 1000.00 not including labor.
Aside from mukluk's link above, there is also a fix using a GM hose which you can read about,
https://www.jeepforum.com/forum/f9/0...w-fix-1335243/
Mine has been doing it for a number of years, just haven't gotten around to addressing it yet.
2005 Rubicon Unlimited, 4" Clayton long arm
35" Mickey Thompsons, lots of stuff
Black Magic Big brake kit
williambmac is offline
post #6 of 14 Old 06-02-2019, 08:25 AM
toximus
Watch the video Mukluk linked to.
I did it on one of mine last month. It completely fixed the problem. Took about an hour for the entire process and will save more than that waiting at the gas pump.
Building the right way for 37s.
toximus is offline
post #7 of 14 Old 06-02-2019, 12:56 PM
RDBills
^^^ This. The GM fuel hose is a band-aid, not a fix. Don't waste your time or money with it.
Mr. Bills
KG6LMV
'06 Jeep "LJ" Rubicon
RDBills is online now
post #8 of 14 Old 06-02-2019, 01:17 PM
biffgnar
biffgnar's Avatar
While I don't disagree about what the ultimate fix is. To say the GM hose is a waste of time or money is a bit extreme. $30 and less than an hour's worth of time is not a big investment and there are people running 5 years plus with them and no sign of problems. Some of it is probably luck. Some of it is in the details of the installation.
biffgnar is offline
post #9 of 14 Old 06-02-2019, 04:35 PM
JEK3
JEK3's Avatar
Mine lasted at least that long, until the bend you have to make in the hose finally collapsed in on itself. If you do the GM hose fix, don't throw away the stock hose.
JEK3 is offline
post #10 of 14 Old 06-02-2019, 06:27 PM
biffgnar
biffgnar's Avatar
I mentioned installation tricks. The bend in the GM hose can be braced with a hose clamp.
biffgnar is offline
post #11 of 14 Old 06-02-2019, 08:20 PM
JEK3
JEK3's Avatar
I did that, but it still eventually gave up and collapsed. However, $30 for about 6 years of use is pretty good, especially since the solution in the video hadn't been discovered yet when I did it.
JEK3 is offline
post #12 of 14 Old 06-03-2019, 06:38 AM
rcroane
As you will read in the numerous links on this subject, another option is to remove the flapper from the GM hose and insert into the original Jeep hose. I went this route and itís working great for me.
rcroane is offline
post #13 of 14 Old 06-03-2019, 07:14 AM
Bruce06Unltd
I did the GM hose swap and it lasted a couple of months...I ended up removing it and putting the original back in and am just careful not to over fill. Maybe I will try dropping the tank and grinding down the check valve as seen on the video. Maybe ;-)
Bruce06Unltd is offline
post #14 of 14 Old 06-04-2019, 04:44 AM
jeep63
jeep63's Avatar
^^^^This. We did this on my sonís 06 LJ and it is still working as expected.
95 YJ-Sold
YJOTM 05/15,05/18
jeep63 is offline
