Gas tank issue - JeepForum.com
 2Likes
  • 2 Post By RDBills
post #1 of 11 Old 08-23-2019, 09:29 PM Thread Starter
stevewolfson
Gas tank issue
Just picked up an 06 LJ with a 6 speed. When filling up the automatic shut off does not shut off and gas come spilling out. Is this a common issue and does anyone know the fix? thx
stevewolfson is offline
post #2 of 11 Old 08-23-2019, 09:56 PM
ravenworks
ravenworks's Avatar
There is a huge thread about this problem
Semper-Fi "81-84"
I.U.O.E. - 18
ravenworks is offline
post #3 of 11 Old 08-23-2019, 11:28 PM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
moved to tech
***Chris***
chris87xj is offline
post #4 of 11 Old 08-23-2019, 11:46 PM
mukluk
mukluk's Avatar
mukluk is offline
post #5 of 11 Old 08-24-2019, 02:56 AM
AjRagno
AjRagno's Avatar
I installed the GM hose a few years ago and it does work just fine to address the overflow issue. I figure I'll modify the back splash valve when it's time to replace the fuel pump.
While you're getting oriented with the quirks of an '06 TJ, make sure you also have a Crown OPDA, or that you are at least aware of the OPDA failure signs.
AjRagno is offline
post #6 of 11 Old 08-24-2019, 06:56 PM
TooManyIrons
TooManyIrons's Avatar
06 LJ w/6 spd, 2.5" SL, 1.25" BL, 1.0" MML, Moab Wheels, 255/85-16 Tires, Exogate, Banks 2.5" Ext
TooManyIrons is offline
post #7 of 11 Old 08-25-2019, 09:13 AM
RDBills
The issue is caused by a sticking anti-rollover valve in the fuel tank. It manifests as either (1) fuel spit back when fueling caused by the valve being stuck open, (2) the gas pump continually clicking off because the valve is stuck closed or nearly closed resulting in it taking forever to fill the tank, or (3) both depending on where the valve is stuck on a particular day.
The GM filler hose hack referenced above is a band-aid that addresses symptom #1 only, it is not a fix for the root cause.
The fix is to drop the tank, remove the anti-rollover valve and sand down the nubs on the plastic plunger a bit until it moves freely, then reinstall. No new parts are necessary and the repair is free if you DIY.
Similar post in a related thread: https://www.jeepforum.com/forum/f9/0...l#post40719735
chris87xj and Kalten like this.
Mr. Bills
KG6LMV
'06 Jeep "LJ" Rubicon
RDBills is offline
post #8 of 11 Old 08-25-2019, 04:40 PM
Kalten
Itís a simple fix and can be done in an hour. If you have or know someone with a motorcycle jack it is even easier.
06 LJ Auto, 4" SL, Synergy Adj CA & Trackbar, 33x10.5 AT KO,
231 w/(WC,2lo,6pinion & JB-C SSYE)
Kalten is offline
post #9 of 11 Old 08-30-2019, 03:27 PM
biffgnar
biffgnar's Avatar
https://youtu.be/V4DXHsacHB4
https://youtu.be/x83vjIclEyk
Dropping the tank is the ultimate fix, but if a band-aid lasts forever there isn't anything wrong with it.
biffgnar is offline
post #10 of 11 Old 08-31-2019, 11:03 AM
RDBills
Except that in this case the "band aid" only covers up one of the symptoms and does nothing to address the slow fill issue that has an equal chance of occurring with a stuck overflow valve.
Its like a tire shop telling a customer, "We found two potential problems with your tire so we put a temporary patch on one of them."
Mr. Bills
KG6LMV
RDBills is offline
post #11 of 11 Old 08-31-2019, 11:17 AM
biffgnar
biffgnar's Avatar
Maybe in theory they have equal chance of occurring but over the last 10 years here the stuck open (and overflow) is much more common by multiples.
biffgnar is offline
