Fuel system problem? - JeepForum.com
post #1 of 2 Old 07-21-2010, 01:30 PM Thread Starter
SCSI2
A few weeks ago my 2006 TJ (4.0 L) turned on the Check Engine light with the code “air in the fuel line”. A mechanic told me to replace the tank fuel cap which I did. Now I see a strange thing. The Jeep runs all right with a full tank. When I leave it overnight with the tank 3/4 or less full, it turns on the Check Engine light at start, it sounds much louder and the idling RPM is a bit higher. If I fill it up and reset the light (by disconnecting the battery for 15 minutes), it is all right again as long as I keep refueling above 3/4 with the hot engine. But once I let it cool down with a tank not full, it starts all over again. Any ideas please?
SCSI2 is offline
post #2 of 2 Old 07-21-2010, 02:10 PM
BulldogTJ98
BulldogTJ98's Avatar
What was the code? P****? The only thing i can think of is 2 things. Your fuel system is a returnless system and the regulator is in the tank, it might be somthing to do with that. Id check the EVAP canister for cracked or damaged hoses first. If somebody told you it could be the cap and it wasn't, its probably a vacuum line to the canister.
My Build Thread:
'98 TJ 4.0L, AX-15 5spd, NP231, RE 4.5 rear, 3"&.75" BB front, JKS discos, 33x12.50 KM2s on Rock Crawlers, 3.73s, Dana30 front, Dana 44 rear, JB Conversions SS SYE, JKS HD Tierod, Warn 8274 Winch, Front Stinger and Rear stinger w/ tire carrier, Rokmen Corners, Aluminum Radiator, LED tailights, Rock Lights, KCs, K&N airfilter, Optima Redtop, Cobra CB and a Sony soundbar
BulldogTJ98 is offline
engine , fuel
Fuel system problem Davpmars YJ Wrangler Technical Forum 3 01-03-2010 05:43 PM
Possible problem with fuel system 2004WRANGLER TJ Wrangler Technical Forum 3 03-18-2009 07:53 PM
Possible Fuel System Problem meBrian YJ Wrangler Technical Forum 12 10-30-2007 09:07 AM
Funky Fuel System Problem Birdlaw TJ Wrangler Technical Forum 3 04-29-2004 07:02 AM
problem involving the fuel system sabrelax17 YJ Wrangler Technical Forum 5 07-25-2003 10:55 AM
