Fuel Pressure Gauge Check - Newbie - JeepForum.com
 1Likes
  • 1 Post By jtec
post #1 of 4 Old 07-30-2021, 02:47 PM Thread Starter
chadwick1875
Junior Member
chadwick1875's Avatar
So, I am checking my fuel pressure on my 03 Wrangler I6 4.0L as I a not sure it is getting fuel (cranks over but no start). I sprayed starting fluid in the intake and in almost started but never did so not sure if it's getting any fuel. I bought this gauge from Harbor Freight and hooked it up and turned the key but don't see any pressure. Now I am wondering if I actually hooked it up correctly. I am new to this and was following a few different posts on how to do this but not sure I have it. Look in picture below and let me know.
chadwick1875
chadwick1875 is offline
post #2 of 4 Old 07-30-2021, 03:54 PM
jtec
jtec's Avatar
2014 JK Wrangler
thats hooked correctly, when cranking engine what is PSI reading?
spec is 49 psi +/- 2 psi.
jtec is offline
post #3 of 4 Old 07-30-2021, 04:09 PM Thread Starter
chadwick1875
Junior Member
I get 0 psi when the key is in the on position and when I crank it. The engine just cranks but not start. Wanted to make sure I was attaching this fuel pressure gauge correctly.
Seems I may have some wiring issue with the power coming to the fuel pump relay in the PDC from what my other thread is saying. See below if you want to comment there for issues I am seeing.
https://www.jeepforum.com/forum/f9/0.../#post41324627
chadwick1875
post #4 of 4 Old 07-30-2021, 04:14 PM
jtec
jtec's Avatar
2014 JK Wrangler
your in really good hands with Rubi4MyMrs.
It is a slow step by step, question and answer back and forth.
chadwick1875 likes this.
jtec is offline
