Front upper frame sway bar nut spinning. Help - JeepForum.com
 1Likes
  • 1 Post By mukluk
post #1 of 3 Old 06-11-2019, 06:45 AM Thread Starter
Que89YJ
Ok here it goes. My first real issue with the TJ. Im dealing with installing a front bumper on the TJ. I start to try and remove the bolts and 1 of the 2 for the sway bar mounts way up inside the frame on each side are spinning. I am installing a currie antirock so I though I was ok....I can use a cut off wheel and get the bolt off but after playing around I found out I need those mount points for a new bumper!
Has anyone dealt with this? They are way too far back in the frame to weld and they are an important mount point for the arb bumper bracket.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #2 of 3 Old 06-12-2019, 01:02 AM
mukluk
mukluk's Avatar
There's a slotted hole in the outboard side of the frame almost directly under your front sway bar mount. Just checked on my LJ for ease of access and can quite easily touch both fasteners; I have confidence I could get a wrench or ratchet on either if I had to. Remove your spinning bolt however you need to, then install a nut through the frame slot.
Que89YJ likes this.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #3 of 3 Old 06-12-2019, 05:28 AM Thread Starter
Que89YJ
Thanks. I'll check it out this afternoon. Really appreciate it.
Sent from my SM-G955U using Tapatalk
Fault codes:
No Start:
Que89YJ is offline
