Front rubi 44 locker in rear D44 - JeepForum.com
post #1 of 12 Old 11-11-2008, 05:00 PM Thread Starter
gribbles
gribbles's Avatar
Ok, will a rubicon 44 front locker work in my rear D44? I know it is a half a*$ed 44. kind of a mix of a d30 and a d44, but will it work? Also I have heard the term 'thick gears' and I know rubicons use these. So will stock D44 shafts work with a rubicon locker and gears? either front or rear. I am not looking at buying new or anything, that would be stupid. Have a chance to get a pretty good deal on a used rubi locker and have heard the front lockers are stronger then the rear.
2000 TJ, 100" wb on leaves
2007 WK CRD
gribbles is offline
post #2 of 12 Old 11-11-2008, 05:08 PM
slate210
Won't fit. The Rubi front 44 is far more D30 than 44. Front lockers are not typically stronger than rear lockers, they just see about 50% less torque. I suppose it could be stronger if you had an old waggy 44 up front and a D35 in the back.....but that wouldn't make much sense.
2000 TJ 4.0 5-SP 115k mi. Patriot Blue - Bone stock...for now.
1997 TJ 4.0 5-SP 134k mi. Red Jeep Club Member
- Some mods...
2006 VW Jetta TDI DSG 54k mi. BLACK Rocketchipped, boostvalve, boost gauge.
slate210 is offline
post #3 of 12 Old 11-11-2008, 05:22 PM
never monday
It will with some spacers. Call Randy's ring and pinion and get the details
never monday is offline
post #4 of 12 Old 11-11-2008, 05:27 PM Thread Starter
gribbles
gribbles's Avatar
Ya, I am not giving up on this one easy. It is stronger in the fact that it doesnt act as a limited slip, and something about the helical gears. Not sure on all the details. Thanks monday, I'll give em a call tomorrow. Does anyone have experience with or have done this themselves?
2007 WK CRD
gribbles is offline
post #5 of 12 Old 11-11-2008, 05:32 PM Thread Starter
gribbles
gribbles's Avatar
Originally Posted by Digger 5 View Post
The front Rubi locker is much stronger than the rear. The rear unit in a helical gear LSD design like a Truetrac. When the unit is locked the power to the right axle is transmitted through the locked helical gears. These gears are very small and when locked are much weaker than a standard 4 pinion diff. We see a lot of Rubi owners replace broken rear units with front units.
this was from another thread, I tried to get the OP to elaborate, and also tried to send him a PM but was not able to do so. Does anyone have any more info on this matter
2007 WK CRD
gribbles is offline
post #6 of 12 Old 11-11-2008, 06:25 PM
mudb8
want it rite or rite now?
mudb8's Avatar
I haven't been able to bust my rear carrier and I just put 37's n another and wnet and beat the crap outta it,
they are prolly hamering on em before it's actually locked in, that will toast em...
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
post #7 of 12 Old 11-11-2008, 07:16 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Yes the front will fit. You will have to shave .100 off of the carrier bearing cap that is notched for the airline. That is done to let the shift collar have enough movement to let the locker unlock and go into open diff mode. Not doing so binds it up and the locker won't unlock.
You will also need thick gears or a spacer for your regular gears depending on the carrier break and what you have.
As far as being stronger, there is some merit to that argument. Given that the limited slip portion of the rear locker is typically what fails and takes out the rest of the locker, not having it is a good thing.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #8 of 12 Old 11-11-2008, 07:19 PM
JeSimmers
JeSimmers's Avatar
As far as being stronger, there is some merit to that argument. Given that the limited slip portion of the rear locker is typically what fails and takes out the rest of the locker, not having it is a good thing.[/QUOTE]
Good to know, thanks
Red Jeep Club Member #454
JeSimmers is offline
post #9 of 12 Old 11-11-2008, 09:10 PM Thread Starter
gribbles
gribbles's Avatar
Awesome, thanks mrblaine.
2007 WK CRD
gribbles is offline
post #10 of 12 Old 11-12-2008, 12:15 AM
Border Dave
Got Sand?
Border Dave's Avatar
MrBlaine:
I have a rear Rubicon locker with the thick gears and was wondering what it would take to put it into the rear Dana 44 on my 01 Sport.
I've heard that the rear locker is a bit wider and the standard (non-Rubicon) Dana 44 housing would have to be somehow shaved to make room for it. Is this true and how would one go about doing it?
David
Border Dave is offline
post #11 of 12 Old 11-12-2008, 12:25 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Originally Posted by Border Dave View Post
MrBlaine:
David
I'm 99.99 percent certain you can't get the Rubi rear locker into a standard D-44 non Rubi housing. The front barely fits with some modifications to the carrier bearing cap and the rear Rubi locker is wider.
In the event that the .01 percent matters, get in touch with Gearman on POR and send him a PM. He will know for certain.
I am Savvy
mrblaine is offline
post #12 of 12 Old 11-12-2008, 03:27 PM
Border Dave
Got Sand?
Will do. Thank you.
Swaping front Rubi locker to rear, drawbacks MikeBK TJ Wrangler Technical Forum 8 06-06-2009 09:45 PM
Rear Rubi locker in front Rubi axle. NotURMailman TJ Wrangler Technical Forum 4 05-08-2009 10:56 PM
rubi front locker Easton04 TJ Wrangler Technical Forum 0 12-26-2008 11:01 AM
Upgrading my Rear Locker-ARB or Rubi Front Locker? tkki1230 TJ Wrangler Technical Forum 4 05-26-2008 08:45 PM
New Rubi D44 front-which locker? Qui_John TJ Wrangler Technical Forum 13 03-09-2006 07:42 AM
