Front D44 locked after seal change - JeepForum.com
 3Likes
  • 1 Post By Mousejockey
post #1 of 9 Old 05-11-2021, 09:23 PM Thread Starter
Mousejockey
D44 is out of a 04 Rubicon, no issues (related) before seal change
Did the toothpick trick, but forgot to tie the string, knocked it out with a slimjim, got the toothpick out
Installed a RuffStuff diff cover, plug is not hitting
Fronts are turning together with abit of 'slop'
Is the air bladder hung up on the 'Locked sensor' ?
Thought Id ask for thoughts before pulling it out again.....
Dont care about the switch, thought about cutting it off when the carrier was out. May just pull it first and see if the issue is solved
Mousejockey is offline
post #2 of 9 Old 05-11-2021, 10:59 PM Thread Starter
Mousejockey
Switch/Sensor pulled still locked......
Does the sensor also retract the ring when the pressure is released?
post #3 of 9 Old 05-11-2021, 11:40 PM
mukluk
mukluk's Avatar
The sensor shouldn't affect the actuator function, no.
Is the air line connected? If yes, does the locker release if you disconnect the line?
Does the locker act the same with the diff cover removed?
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #4 of 9 Old 05-12-2021, 08:51 AM Thread Starter
Mousejockey
No joy on the air line disconnect, thought about trying vacuum on it but dont think that would do anything
Will pull the cover tonight after work
Also need to figure out why the transfer cast is not shifting smoothly, Savvy cable, lined up with the 2 shifter ends. At times it works smooth, other times it binds going from 4Hi to N.
post #5 of 9 Old 05-12-2021, 04:24 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Even though you forgot to tie the string to the toothpick and you managed to get it out with a slimjim, I'm still betting it's hung up with the actuator plate. Especially since you removed the diff cover filler plug to check that it wasn't seated too deeply and hanging up the locker.
Jerry Bransford is offline
post #6 of 9 Old 05-12-2021, 05:26 PM Thread Starter
Mousejockey
Also removed the sensor, could feel it hang on the plate as I removed it, had to wiggle n jiggle it out.
Pulling the cover now....
post #7 of 9 Old 05-12-2021, 06:24 PM Thread Starter
Mousejockey
Popped the cover and saw where the issue was, but not why
So I removed the lower bolt and found this
I had not removed the bolt when doing the seals, pulled the cap/bolts with the carrier. once I loosened the top bolt the plate sprung out and freed up.
mukluk likes this.
post #8 of 9 Old 05-12-2021, 06:36 PM Thread Starter
Mousejockey
Everything seems to be working, would rather not replace the actuator
Thinking Ill remove the burr on the lower left, put the bolt in, turn the locker on to keep the assembly snug on the bearing cap and bend the piece back around the bolt. Wedge something to keep it in place and retorque the cap bolts
Jerry Bransford likes this.
post #9 of 9 Old 05-13-2021, 11:15 AM Thread Starter
Mousejockey
All is working as designed now
Thnx for the info
