Front Axle Hub Bearing Flange Question - JeepForum.com
 4Likes
  • 1 Post By TheBoogieman
  • 2 Post By mrblaine
post #1 of 10 Old 10-19-2019, 07:02 AM Thread Starter
2jhanna
I pulled my front axle shafts to change the inner seals. I noticed that on the 2 axles, the flange behind the hub unit bearing was facing differently, as shown in the picture below.
Unless this was done, one side reversed, during the first 5 years of its life, I assume it came from the factory this way.
Not that I going to change it, but which way is correct? The shaft on the left with the red showing is the driver's side.
I am multi-talented, I can talk and piss you off at the same time.
jhanna
denton county, tx
2jhanna is offline
post #2 of 10 Old 10-19-2019, 12:16 PM
mukluk
mukluk's Avatar
Just checked both Jeeps: on the '00 that I've owned since it had two miles on the clock and know both axle shafts are original, both flanges face the axle u-joint; on the '05 that I've owned since 34k miles on the clock and believe both axle shafts are original, both flanges face the hub. I guess you can take your pick which direction the flange faces.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #3 of 10 Old 10-19-2019, 04:08 PM Thread Starter
2jhanna
thanks. this explains everything and it makes total sense now. since you have a 00 and a 05, it makes perfect sense that my 02 was the "transition year". that's why one side is one way, and the other side the other way.
the passenger side axle shaft assembly line got the memo before the drivers side axle shaft assembly line.
I always thought my TJ was special.
jhanna
denton county, tx
2jhanna is offline
post #4 of 10 Old 10-21-2019, 07:58 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Neither is actually correct for a sealed unit bearing. One can make a case that the flange on the slinger is doing some good acting as a debris guard when it is close to the back of the UB but that's it. The other one is wholly wrong since it is a carryover from an actual spindle and locking hub design and it carried a V seal that butted up to the back of the spindle to keep water/dirt out of the bearings. Without the V seal and the big gap between the flange and the back face of the UB, it is useless.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #5 of 10 Old 10-21-2019, 09:13 AM Thread Starter
2jhanna
I just find it really odd how inconsistent the orientation is. Not only from year to year, but even within a year like my 02. I have every reason to believe that my axles are not only original but have never even been removed before this past week.
jhanna
denton county, tx
2jhanna is offline
post #6 of 10 Old 10-21-2019, 09:53 AM
TheBoogieman
Distubed Jeepaholic
TheBoogieman's Avatar
My 99' and 03' both look like the right side pic.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
03' Rubicon/Zone 4" coils with 1" spacers up front/Rancho shocks/5.13 gears-35" MTZs/BM brakes
99' XJ / 5.5" lift / Rancho shocks/33" DC Extreme country MTs. Jeep #18
TheBoogieman is offline
post #7 of 10 Old 10-21-2019, 10:10 AM
TheBoogieman
Distubed Jeepaholic
I guess that's why my Jeep built in June of 02' has one square mirror and one rounded style one. Thanks for clearing that one up for me. A transition year special Jeep. I thought the PO was just too cheap to buy two.
Olsen likes this.
post #8 of 10 Old 10-21-2019, 10:27 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
They are essentially a useless artifact from the older spindle and wheel bearing design so it makes little difference how they are mounted.
TheBoogieman and shortydog33 like this.
I am Savvy
mrblaine is offline
post #9 of 10 Old 10-21-2019, 11:25 AM
TheBoogieman
Distubed Jeepaholic
Glad to see you posting here again. I thought you got sick of stupid questions. Real experts are rare IMO.
NashvilleTJ likes this.
post #10 of 10 Old 10-21-2019, 03:37 PM Thread Starter
2jhanna
Thanks Blaine and others for the input. When I first saw the different flange mountings, my first thought was, "that's not right, I need to fix it". Then my second thought was, "it's been that way for 17 years, and if it ain't broke, don't fix it".
I do see where the flange toward the hub bearing would offer more protection, and if I ever have that side apart, I can "fix it" at that time.
jhanna
denton county, tx
2jhanna is offline
