Frame rust - JeepForum.com
post #1 of 12 Old 09-27-2012, 09:58 AM Thread Starter
packersxxxi
Frame rust
Ok so i know theres a lot of threads about this but i thought i just ask again... The other day i noticed a decent amount of rust on the frame on both sides where the skidplate is attached... I can also see the inside is beginning to rust... I want me jeep to last for a very long time and i want this taken care of right away... What are your suggestions for me to do? So far i was looking at rust bullet for the outside and eastwood internal frame coating.. Also what steps do i meed to take becore and after? Thanks!
2000 Jeep Wrangler Sahara, 95,000 miles, Jensen VM9214, Sony Xplode 12", Kenwood 350w amp, KC Hilites 130w Long Range lights, Warn VR8000 Winch.. Build List: 3" BDS Suspension Lift with Fox 2.0 shocks, Pro Comp Rock Crawler 152 Rims, 33x12.5 Goodyear MT/R's, LOD Rear Bumper, Metalcloaks front and rear, tom wood's SYE and CV driveshaft
packersxxxi is offline
post #2 of 12 Old 09-27-2012, 09:59 AM Thread Starter
packersxxxi
This is the worst spot
post #3 of 12 Old 09-27-2012, 10:07 AM
Zombi
If thats you worst spot you're lucky. That frame looks to be in great shape for having spent it's life in New Jersey.
Wire wheel the scale off and coat with paint of your choice, rubberized undercoating, waxoyl etc. Whatever works for ya'. Eastwood sells some metal prep products designed to "convert" rust into a phosphate coating. It actually seems to work pretty well based on my experience. Get some of that, hose down the inside of the frame with it, let it do it's job and topcoat with some sort of paint.
Just for comparison, this is what's inside MY frame after roughly the same amount of time:
Call me Z
Originally Posted by mrbates View Post
Zombi's are in fact very unpleasant to be around, they smell, and bite--also, they eat babies.
Zombi is offline
post #4 of 12 Old 09-27-2012, 10:09 AM Thread Starter
packersxxxi
Oh wow thats insane... I havent actually seen a picture of the inside just looked quick through the hole hopefully mine isnt too bad
post #5 of 12 Old 09-27-2012, 10:15 AM
Zombi
The inside of your frame wont likely be as bad as mine. What you could do is take a blowgun with an angled extension and jam it into the frame to blow out loose debris.
Call me Z
Zombi is offline
post #6 of 12 Old 09-27-2012, 10:30 AM
Jsinclair
I took a shopvac and taped a peice of hose to nozzel fished it threw my frame to remove that scale. I was able to get about 99% of the rust scale out and then coated it with eastwood internal frame coating. I coated the outside of the frame with Chassis saver and overall I've been pleased with the results.
Jsinclair is offline
post #7 of 12 Old 09-27-2012, 12:41 PM
VietVet67
Dam those pic's make me GLAD i live in Oregon where they don't use salt but i feel your pain!!!
Silver Jeep club member #76 Semper -Fi my brothers
VietVet67 is offline
post #8 of 12 Old 09-27-2012, 01:13 PM
sailsurf7713
Spay the nutserts with penetrating oil for a good couple weeks using the holes in the side of the frame and then heat them up really good and take the T.C. crossmember off and paint thoroughly then reassemble with a liberal amount of anti-seize. Also clean out the body mount rail on the tub and spray that with the eastwoods. That'll surely go next.
I hate salt.
'99 SE: The "It could be worse..." jeep
Originally Posted by 97flexy View Post
...I say don't lift but CUT. :)
sailsurf7713 is offline
post #9 of 12 Old 09-27-2012, 01:21 PM
Monomoy
Rust
Ha. That's nothing.. Pic of my brother's jeep.. (kinda off topic I know...)
Monomoy is offline
post #10 of 12 Old 09-27-2012, 01:44 PM
Zombi
He ever get that thing fixed? I remember that pic from your other thread.
Call me Z
Zombi is offline
post #11 of 12 Old 09-27-2012, 04:54 PM
DKenyon28
DKenyon28's Avatar
Holy crap! That's crazy!
DKenyon28 is offline
post #12 of 12 Old 09-28-2012, 06:37 AM
Monomoy
rust
Its up for sale...frame replacement quotes ranged from $4K to $6K.
Monomoy is offline
