frame or Frameless Soft Top - JeepForum.com
 5Likes
  • 2 Post By Ross
  • 1 Post By NashvilleTJ
  • 2 Post By NashvilleTJ
post #1 of 9 Old 03-10-2019, 08:19 PM Thread Starter
TeamDem4
Hey There,
So I'm sure this topic has been covered before, but a quick search and I could not come up with a good thread to read.
It is time to retire my existing soft top. I would really like to get a frameless top. I like the fastback look and don't particularly like the look of the framed top piled up on the back of the jeep when the top is down. However, I live in a part of the country where rain can pop up at anytime with little notice during the summer so I need something that I can put up quickly. Not only that, I need a way to carry it with me when I'm out and it is not on.
Has anybody tried this with the frameless top? Where can you carry the bikini top and windows when they are off, or do you just accept that it will always be on? I like that they come with a pocket for the side windows though is seems like a lot of bulk do have hanging over my head.
Please share your thoughts. Should I just go the easy way out and replace the soft top using the existing hardware, or make the jump to a frameless top?
Thanks
TeamDem4 is offline
post #2 of 9 Old 03-11-2019, 12:33 AM
TheBoogieman
Distubed Jeepaholic
TheBoogieman's Avatar
I loved my Bestop Trektop NX with the flip back sunroof option. I never removed the entire top after that.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
03' Rubicon/Zone 4.25" combo lift/Rancho 9000XL shocks/5.13 gears-35" MTZs/LoD bumpers
Desert Sand 99' XJ Classic (JEEP #18) ) 5" BDS lift / HP30/ 8.25/ 33x12.50" DC Extreme Country/Tactik black satin wheels.
TheBoogieman is online now
post #3 of 9 Old 03-11-2019, 10:30 AM
freedom_in_4low
same here. I live in Colorado, which has a monsoon season from June into September where if you're near mountains, every afternoon has a chance of rain whether the meteorologists predict it or not.
I use a hardtop during snow season and I have the Trektop NX with the sunrider that I use from May to November. I never go completely topless, because the sunrider gives me enough of a topless sensation that I don't feel the need to. Last summer I only had the windows on for a total of a few days, and the doors maybe a couple of weeks.
Joe
1999 TJ Sahara
2008 MINI Cooper S
2010 Toyota 4Runner
freedom_in_4low is offline
post #4 of 9 Old 03-11-2019, 06:08 PM
tyvanwie
tyvanwie's Avatar
1993 XJ Cherokee
I vote frameless
tyvanwie is offline
post #5 of 9 Old 03-12-2019, 12:30 PM
Kalten
I briefly had a frameless soft top from Rampage. You could store all the windows between the soft top and a flap under the soft top. Kinda like the design but sold the top after a week of use (it came with the Jeep when I bought it along with the hard top and a factory soft top) because it made the backseat useless for anyone in my family since we are fairly tall and our heads hit the top. Does not happen with the hardtop or the OEM soft top with the frame.
06 LJ Auto, 4" SL, Synergy Adj CA & Trackbar, 33x10.5 AT KO,
231 w/(WC,2lo,6pinion & JB-C SSYE)
Kalten is offline
post #6 of 9 Old 03-12-2019, 01:20 PM
Ross
I was thinking about going frameless but then I discovered I could use the space between the sound bar and soft top for transporting fishing poles.
The27Jeenyus and NashvilleTJ like this.
01 TJ,33X12.5Flaken WP ATs,Winch, ARBs F&R, belly up, some armor,4.0,5spd
Ross is online now
post #7 of 9 Old 03-12-2019, 02:00 PM
NashvilleTJ
I miss the snow...
NashvilleTJ's Avatar
I run the Rampage on my LJ and I really like it. I almost never remove the bikini - mainly due to the intense sun here in Nashville. It takes just a few minutes to remove the side and rear windows, and you can tuck them up under the top. It is more involved to completely remove the Rampage than to remove the stock soft top, since on the stock top I just removed the pins holding the bars on and then pulled the entire thing. The Rampage takes a bit more effort than that since the "inner liner" straps down to the cage. On the LJ, I think the Rampage looks much better than the stock top.
The main reason I went to the Rampage was the easy transition from the full top configuration to the Bikini. Prior to the Rampage I was constantly completely pulling the stock top and putting on the bikini, and then pulling the bikini and reinstalling the soft top. Much easier now.
Here is the bikini config and the full top config.
TheBoogieman likes this.
Build Thread:
Swing Away / Swing Down Tire Carrier:
NashvilleTJ is offline
post #8 of 9 Old 03-12-2019, 02:07 PM
NashvilleTJ
I miss the snow...
To give you an idea how much I liked the Rampage, I had to make a slight modification to my roll cage to make it fit...
TheBoogieman and The27Jeenyus like this.
Build Thread:
post #9 of 9 Old 03-12-2019, 05:25 PM
CJRoberts8812
I have a Rampage bowless that I'm fond of. But you'll NEVER get it up in time to not get wet in case of sudden rain. It's about a fifteen minute process to get it up, though it would be less if you had the door surrounds attached.
CJRoberts8812 is online now
99 TJ Soft Top / Hard Top mmitsch TJ Wrangler Technical Forum 8 03-03-2019 01:20 PM
OEM Soft Top with Frame for 2003 TJ Rubicon bdserv Body & Interior Parts 3 06-26-2018 06:51 AM
LJ Rampage Frameless Soft Top TJJeepJosh Body & Interior Parts 8 05-18-2018 08:55 PM
1994 YJ replacement soft top issues Sciorty YJ Wrangler Technical Forum 3 04-08-2018 12:30 PM
1994 YJ Soft top issues Sciorty YJ Wrangler Technical Forum 2 04-07-2018 09:19 AM
