ford 9 - JeepForum.com
post #1 of 17 Old 11-26-2007, 05:30 PM Thread Starter
never2fast14
Guest
ford 9
Hey guys i found a ford 9 with tj brackets already installed with a spool and 4.88. sounds like my dream axle. It has 5x5.5 bolt pattern though. The guys says the rotors are drilled or 5x5.5 and 5x4.5. My question how hard would it be to convert the axle shafts over to 5x4.5? he was 1k for the axle. sounds like a deal? would it be absolutely necessary to run a sye and cv? thanks
never2fast14 is offline
post #2 of 17 Old 11-26-2007, 06:34 PM
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
as for getting the shafts re drilled you could probably take them to a machine shop and have them drilled or get a set of Moser shafts or something similar. If they are after market shafts the may have both patterns on the shafts.
as for the SYE. being that your profile gives up a big 0 when it comes to your rigs specs i doubt it would be possible.
http://www.truehi9.com/driveshaft2.html
that shows that the ford 9" is about an inch and a quarter lower than a D44
97 TJ 37s custom long arm
Gen right stretch tank
03 TJ buggy project. Stretched tub to LJ, Goat Built chassis, tons 42 pit bulls
04 QCLB 4wd Cummins tow rig
24 Gooseneck PJ trailer
JeepRocks86 is offline
post #3 of 17 Old 11-26-2007, 06:39 PM
plowe
i.e. fill in your profile
plowe is offline
post #4 of 17 Old 11-26-2007, 06:45 PM
Corey4x4man
I would switch your front to a 5.5 then you could run bigger brakes also. this is what I am doing. but yea you can go to a 4x 4.5 if you want.
98 tj 4.0, 4" RC, 1" body,4.88s, Auburn ECTED in front, 8.8 with ARB in rear, rollin on 35s. JKS discos, SYE/CV DS, MML, milemarker 8000, homemade OBA, more to come it never stops.
Corey4x4man is offline
post #5 of 17 Old 11-26-2007, 07:06 PM
chandlerr
chandlerr's Avatar
don't you mean 3/4" lower?
2004 Black Rocky Mountain Edition, Clayton 4 Linked w/ 4" Pro Comp Springs, 37" Iroks (lost to Mexico. RIP Krystal)
2006 Black LJ Rubicon, stock suspension w/ 33's
chandlerr is offline
post #6 of 17 Old 11-26-2007, 07:09 PM
PBR
Guest
if I have a currie HP 9" can i swap the 3rd member for a Hi9
PBR is offline
post #7 of 17 Old 11-26-2007, 07:37 PM Thread Starter
never2fast14
Guest
so right now i have 3 in teraflex lift. with a dana 35. i have no sye and no t-case drop. Very minimal vibes. Im thinking since i stretched the distance with the lift it would not be that bad until i got a sye. this sound like a deal guys? it has 35 spline shafts!
post #8 of 17 Old 11-26-2007, 07:53 PM
98TJ
98TJ's Avatar
sounds like a good deal to me but i have no clue what these are going for. is this a trail only rig?
98TJ is offline
post #9 of 17 Old 11-26-2007, 08:03 PM
JerryC
Yes you can.
JerryC is offline
post #10 of 17 Old 11-26-2007, 08:42 PM Thread Starter
never2fast14
Guest
no its a dd. but i do have a suburu to play around it too. i really hoping that i could do this without too much hassle.
post #11 of 17 Old 11-26-2007, 09:15 PM
chandlerr
chandlerr's Avatar
if it's a dd, i would rethink the spool locker if I were you (however it looks like a very good deal if the axle is in good condition); I think you're limited in your 35 spline 9" carrier options...I just ran into this same problem but I think I'm going with the arb
post #12 of 17 Old 11-26-2007, 09:42 PM
JeepRocks86
it's an inch and 3/4 lower than center lower than the center of a D 44. so it's like 2.5" off of the center line (below).
a hi 9 will bolt up to a 9" housing.
with that amount of lift you could possibly run it with out an SYE, but chances are that you would eat U joints even if its a trail rig.
post #13 of 17 Old 11-26-2007, 10:02 PM
jdragger
That axle is a abuy. But, a real spool on the street is going to drive you nuts. Squeel at every turn, wear tires, not be the most controlable thing either. 35 splines are very tough, but lockers to match may be tough to find. You can get the axle flanges redrilled. Maybe Currie can do that.
jdragger is offline
post #14 of 17 Old 11-26-2007, 10:14 PM
newbs
Jeepaholic
35 spline detroits and arb's are easy to find, I have a detroit in my garage and an arb in my jeep. If price is a concern get the detroit which can be found on ebay fairly cheap and the arb cost and arm and a leg.
newbs is offline
post #15 of 17 Old 11-27-2007, 04:26 AM
chandlerr
chandlerr's Avatar
unless I'm reading it wrong:
- 2.25 Ford 9 (w/stock pinion support)
- 1.5 Dana 44
-2.25-1.5 = -.75
Help With Ford 9", or Ford 8.8 Cbaughn YJ Wrangler Technical Forum 10 10-29-2008 05:39 PM
Ford SVO disk brake kit on Ford 8.8 texashoghunter TJ Wrangler Technical Forum 0 07-10-2008 07:12 PM
Ford 10.25 vs Ford 9" Allen52105 YJ Wrangler Technical Forum 1 07-24-2007 06:45 PM
Ford 8.8 ???? mud chicken TJ Wrangler Technical Forum 12 01-31-2006 06:29 PM
Ford T18 and Ford Dana 20 JOKER4INK YJ Wrangler Technical Forum 0 11-23-2005 05:00 PM
