Flat tire mystery? - JeepForum.com
post #1 of 14 Old 08-12-2007, 02:27 PM Thread Starter
CHRRRIS
Guest
Flat tire mystery?
So yeaaa, I'm going to a tire shop tomorrow to have them try to solve the mystery, but figure to pass some time before I'm off to work I'll let you guys try to be the Sherlock Holmes' in this case.
So, Friday night I drove maybe 15 miles to then 15 miles from a movie theatre (The Simpsons Movie) and the TJ was great. Didn't notice any problems with steering, it was nromal as usual. Saturday around noon-ish I'm going to pick up my friend to go frolfing... I come up to a stop light, and a pick-up is on my right hand side waiting to turn left onto the street I was coming from... He turns then slows down right by me (top is off) I turn down my radio and he says "Your front passenger tire is flat!!!) I said really, he said yea, I said thanks...
Then I un-belted and checked the tire, and it's flat... luckily just past the stop light is a gas station, so I pull right next to the air machine and check it out...
The tire's not completely flat, but damn near it... right away I scavenge for $0.75 to get the air machine going and air up to about 30psi...only had time to do both front tires to 30, back tires looked just as good.
So throughout the day it looked like it's been holding the air fine, and I've driven maybe 30 more miles in the day, but just this morning I check it, and it's lower than last night...
There's no hissing, it's definately a slow leak... but like I said, it just started out of nowhere, I don't remember any pot holes or hitting anything major in the last couple of days...
Anybody have any ideas on what to check/what to look for? I've looked all around the tread and can't find anything punctured in the rubber, nor any signs of cracks... I just don't know.
But like I said, tire shop tomorrow, just wanted to see if any of ya'll have had a similar situation.
Edit: Lift/tire/wheel forum is too slow, I actually would like some responses.
CHRRRIS is offline
post #2 of 14 Old 08-12-2007, 02:34 PM
tjwoo
tjwoo's Avatar
check the valve stem area. it might have caught a nick right behind the cap or something.
tjwoo is offline
post #3 of 14 Old 08-12-2007, 02:41 PM
Grandpa Jeeper
Grandpa Jeeper's Avatar
With the tire full of air use soapy water applied with a paint brush. You will get bubbles forming where the leak is.
The world belongs to those who show up. Get involved!
Grandpa Jeeper is offline
post #4 of 14 Old 08-12-2007, 02:41 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Spray or douse the tire with a mild soapy water solution which may show the presence of bubbles streaming from the leak. :
Jerry Bransford is offline
post #5 of 14 Old 08-12-2007, 02:42 PM
rubiweeler
The stem itself could be leaking, They get crud in them sometimes when you air down, and it causes a slow leak. Do you have caps on the valve stems?
How long have you had the tires, the bead might not have sealed when they put them on if it got some stuff in there.
Edit: Try with the soapy water.
Superior axles doesn't honor their warranty. Don't buy from them.
rubiweeler is offline
post #6 of 14 Old 08-12-2007, 03:48 PM
docbud
The Mac Lover
docbud's Avatar
Could simply be a bad bead. I've had that happen.
Support bacteria. It's the only culture some people have
docbud is offline
post #7 of 14 Old 08-12-2007, 07:53 PM
tcox
a nail maybe? a small cut? valve? some of the things i had to fix today at work
stuff
tcox is offline
post #8 of 14 Old 08-12-2007, 09:01 PM
04WranglerX
Guest
Check carefully around the base of the valve stem with the soapy water idea.. I see that alot.
04WranglerX is offline
post #9 of 14 Old 08-12-2007, 10:13 PM
arbby
2005 KJ Liberty
If you have an aluminum rim, it could be the valve. They suck up more crap than any others. The Bead of the rim may be slightly oxidized and a crack opened up in the bead.
If its a steel rim, the bead could be rusted and need to be ground down.
It could be a nail as well, get it plugged and be on your way! No need for a patch unless its bigger or on the upper half of the sidewall.
The core could be bad as well and thats a very easy fix.
At work we use Seek-a-Leak and it works magic! As the others said, the soapy water will do the same trick.
good Luck!
|l,[___],
l---L--OlllllllO
()_) ()_)--o-)_)
Gone: 1993 YJ
arbby is offline
post #10 of 14 Old 08-12-2007, 10:32 PM
Big-E
Guest
There's no mystery, you have a leak. Find it, fix it.
Big-E is offline
post #11 of 14 Old 08-13-2007, 12:10 AM
killas1mo
killas1mo's Avatar
I had that happen and I figured that is was leaking arond the bead. Had a bunch of crap in there. Had it taken off and cleaned and put back on......been great ever since.
97 TJ 4.0 5 speed
4.5" RE + 1" BL
33" BFG M/T's (going to 35" tires after 8.8)
Milemarker PE 8000 winch
Aussie in D30, damn D35 out back (8.8 time!)
killas1mo is offline
post #12 of 14 Old 08-13-2007, 12:16 AM Thread Starter
CHRRRIS
Guest
Cool... I'll do the soapy water technique later tomorrow/today to find the leak.. if I don't get anything that way, I'll still take it to the shop incase the tire needs to come off and have the bead cleaned.. If that's the case, I wanted my white letters in anyways..
CHRRRIS is offline
post #13 of 14 Old 08-13-2007, 01:07 AM
87warrior
87warrior's Avatar
My mystery tire flattening was caused by a loose valve stem, the deal inside that on some applications remove to install slime or the like. I simply grabbed some needle nose pliers and tightened it up.
03
(Rubicon build)
92
(92/99 Comanche Project)
86
(Heavy Four)
87warrior is offline
post #14 of 14 Old 08-13-2007, 07:49 AM
Sweeney
My friend who owns a shop had a slowly deflating tire. It turned out that the aluminum wheel had a tiny hole, most likely a "cold shut" in the casting process, that made its way through about 2.5" of metal. You couldn't see it but it was bubbling the soapy water.
Sweeney is offline
Sounds like I have a flat tire, but only when slowing down... Xander TJ Wrangler Technical Forum 13 03-16-2009 10:21 AM
Have you changed a flat tire yet? Egmont JK Wrangler Technical Forum 2 04-11-2007 08:16 PM
flat fendering tire size lonestarrebeltx TJ Wrangler Technical Forum 15 03-02-2006 02:54 AM
Changing flat tire? Weiland TJ Wrangler Technical Forum 11 10-17-2004 01:43 PM
Mystery Flat Tires? swoodnj YJ Wrangler Technical Forum 6 01-06-2003 03:52 PM
