Finding Exhaust Leaks - JeepForum.com
 1Likes
  • 1 Post By 2jhanna
post #1 of 13 Old 08-12-2020, 04:20 PM Thread Starter
Kiwi_TJ
Hi There,
I have a leak in my exhaust, which I think is just the donut between the header and the down pipe, because the bolts rattled loose and I just nipped them up again instead of replacing the donut.
But I thought that I should double check the source of the leak before I pull it apart so is there a good way to do this? Can you spray water and dishwash liquid on it and look for bubbles or anything like that?
1997 TJ Soft Top/ Half Doors
4.0 I6 with 5 Speed Manual | K&N Panel Filter | D30/D44 | 3.07 Gears | Banks Torque Tube Header
31*10.5 R15 Maxxis Trepador Radial Tyres | 2" BDS Spring Lift | Bilstein 5100 Shocks | JKS Discos | JKS Rear Swaybar Links | 100W Narva Spotlights
Kiwi_TJ is offline
post #2 of 13 Old 08-13-2020, 08:18 AM
Mousejockey
Loosen the bolts, realign the pipe to be square with the manifold, then tighten each nut a little at a time to pull the pipe evenly to the manifold.
Mousejockey is offline
post #3 of 13 Old 08-13-2020, 08:55 AM
2jhanna
Don't know if it's different by year/engine/etc, but I recently had my Y pipe down, and was surprised there were no donuts or gaskets of any type. Just the taper and flaring of the mating ends.
And, as stated above, once I got all bolts started, I gradually snugged up on them a little at a time, in turn, until all snug, then even torqued each one at a lower setting and final at the spec setting.
I am multi-talented, I can talk and piss you off at the same time.
jhanna
denton county, tx
2jhanna is offline
post #4 of 13 Old 08-17-2020, 06:41 PM Thread Starter
Kiwi_TJ
I have been looking over a few threads on exhaust leaks. A number of them say that replacing the motor mounts is a good idea to reduce things moving around stressing the welds.
Any advice of which motor mounts are the best for replacements?
Kiwi_TJ is offline
post #5 of 13 Old 08-18-2020, 08:22 AM
LumberjackLloyd
Brown dog is a very popular option.
LumberjackLloyd is offline
post #6 of 13 Old 08-18-2020, 08:48 AM
Mousejockey
I have the BD mounts, they are OK
However I now think that the riser block style, under a factory mount would be the better option.
Factory mounts give better isolation than the aftermarket rubber/poly ones
post #7 of 13 Old 08-18-2020, 04:01 PM Thread Starter
Kiwi_TJ
I have been reading a few reviews on the M.O.R.E Torsion Rubber Mounts, anyone have any experience with these compared to the Brown Dog ones?
I am keen for some with good isolation, rather than poly mounts as it is my daily driver.
Kiwi_TJ is offline
post #8 of 13 Old 08-18-2020, 08:36 PM
Vinman
Hi There,
Take a shop-vac, connect the hose to the exhaust side so it blows instead of sucks, stick the hose up the tailpipe and spray all the exhaust connections with a dish soap/water mixture and look for bubbles.
Vinman is offline
post #9 of 13 Old 08-18-2020, 09:01 PM
2jhanna
Neat trick. But does it cause the engine to rotate backwards
Vinman likes this.
jhanna
denton county, tx
2jhanna is offline
post #10 of 13 Old 08-19-2020, 07:06 AM
Vinman
Also gives you 5 reverse and 1 forward gear🤪
Vinman is offline
post #11 of 13 Old 08-19-2020, 04:38 PM
willis36
willis36's Avatar
You can suck a small amount of atf through the intake, that will reveal any leaks in a hurry, just dont do to much. I had the MORE engine mounts for a long time, they are nice but you will have more vibration, mainly at idle, than the stock mounts. I went back to stock when I did my Savvy under armor and noticed it smooth out.
willis36 is offline
post #12 of 13 Old 09-02-2020, 04:07 PM Thread Starter
Kiwi_TJ
How tight do you do up these exhaust flange bolts? I know the manual says 23 ft-lb, but no way I can get the torque wrench in there. So do you just snug the bolts up or really wail on them to get the FT?
Kiwi_TJ is offline
post #13 of 13 Old 09-02-2020, 04:19 PM
2jhanna
I used a torque wrench. I had already stacked up a variety of extensions and swivels just to get the bolts in, pretty easy at that point to switch to torque wrench
And I did mine in 3-4 steps to insure both sides were the same.
jhanna
denton county, tx
2jhanna is offline
