Engine rattle - JeepForum.com
post #1 of 4 Old 07-22-2003, 06:21 PM Thread Starter
steelerman
Guest
Engine rattle
My jeep runs fine. Just when I turn it off, sometimes I get a little engine knock. My oil was changed just recently and is at the full level. I just put some fuel injector cleaner in there. Any other clues what it could be?
steelerman is offline
post #2 of 4 Old 07-22-2003, 09:23 PM
DennisBlevins
DennisBlevins's Avatar
My catalytic converter started rattling at 79K miles, just before the 80K emissions warranty was about to run out. I had a $350 exhaust job done for free under warranty. You would always hear it when you turned off the ignition. Maybe that's what you're hearing? Good luck.
Behold the turtle...He makes progress only when he sticks his neck out!
DennisBlevins is offline
post #3 of 4 Old 07-22-2003, 09:25 PM
Dee Cue
Dee Cue's Avatar
Is yours a 5 speed by any chance? Mine rattles when I shut it off too... However if I press down on the clutch while shutting it off, the noise doesn't appear. I think it's the tranny but can't say for sure.
Blk, '05 LJ, 6-spd, 3" Zone SL, 33" BFG AT on Soft 8's
Dee Cue is offline
post #4 of 4 Old 07-23-2003, 05:42 AM
Jeep-Ne-Time
Guest
it is the tranny and I was assured that it is just noise of it still spinning a little. pressing the clutch does totally disengage and the rattle goes away. HTH no harm should come either way and it happens to all five speeds that I know of.
Mark
Jeep-Ne-Time is offline
Engine rattle on ignition justin102 TJ Wrangler Technical Forum 1 08-02-2009 02:27 PM
Engine Rattle Matador009 JK Wrangler Technical Forum 1 07-21-2009 05:44 PM
Rattle at back of engine blake989 YJ Wrangler Technical Forum 1 07-22-2007 11:21 PM
rattle when shutting engine off mrtolkien TJ Wrangler Technical Forum 2 06-24-2007 05:48 PM
Engine Rattle rbowling TJ Wrangler Technical Forum 17 01-03-2005 07:19 PM
