Engine power decreases on the highway - JeepForum.com
post #1 of 11 Old 02-06-2015, 03:38 PM Thread Starter
cwebb
Hi everyone,
Hoping you guys can help me out. On my way home today I turned onto the highway and began accelerating. As soon as I get to around 40mph the car stops accelerating. The speedometer thinks it is still accelerating and keeps climbing up to 70 mph if I keep my foot on the accelerator. Engine rpms increase as well. Everything seems normal except that fact that the jeep still is going 40 mph when it should be at 60+. Any suggestion? Its a 2002 6L Manual TJ Wrangler.
At lower speeds everything is fine. But as soon as I get to around 40mph the issue occurs.
Thank you for any advice!!!
cwebb is offline
post #2 of 11 Old 02-06-2015, 04:20 PM
NHfireLJ
NHfireLJ's Avatar
Please fill in your profile?
Have you checked your transmission fluid? Any error codes?
AUDREY...95 YJ UNLIMITED LS
LUCY...2005 Unlimited "LJ" Rubicon Sahara #495
SOLD
BETTY...94, Stroker 4.6,35"s, SOLD
style intake
NHfireLJ is offline
post #3 of 11 Old 02-06-2015, 05:04 PM Thread Starter
cwebb
No error codes and transmission fluid is full.
cwebb is offline
post #4 of 11 Old 02-06-2015, 05:10 PM
Lastshot
Lastshot's Avatar
You say its a 5 speed? How's your clutch doing?
{Project
-'05 LJ build }~{SOLD '98 TJ -
{You know you drive a TJ
gily25 Says...
Issues only become problems when you don't have the tools or time to fix it.
Mike318 Says...
I like my 4.0L like I like my ****... stroked and blown. :duhrock:
Lastshot is offline
post #5 of 11 Old 02-06-2015, 06:02 PM
frenchy206
frenchy206's Avatar
How do you know what speed you're actually going then? Did you use a gps to make sure determine your actual speed?
03 TJ Rubicon
frenchy206 is offline
post #6 of 11 Old 02-06-2015, 06:08 PM Thread Starter
cwebb
Yes after I was pretty obviously going slow I powered up the gps. I was topping at about 40mph but speedo read 70mph...could it be fuel pump or the CATs?
cwebb is offline
post #7 of 11 Old 02-06-2015, 09:59 PM
frenchy206
frenchy206's Avatar
No. Usually a fuel pump goes out completely. Cats would restrict power. It sounds like a drivetrain issue, such as clutch.
03 TJ Rubicon
post #8 of 11 Old 02-06-2015, 10:13 PM
Knuckelhead
R.I.P. Knuckelhead
Knuckelhead's Avatar
Fuel pumps can have several levels of failures. Pressure, volume, check valve.
How could it be a clutch issue when the speedometer is driven by the transfer case output shaft?...
Gone but not forgotten.
Knuckelhead is offline
post #9 of 11 Old 02-06-2015, 10:53 PM
frenchy206
frenchy206's Avatar
Fuel pumps can fail as you described above, however most that I have seen fail, either work or don't.
You are correct. I forgot that the speedometer is driven by the transfer case output shaft.
So...what could be the problem?
03 TJ Rubicon
post #10 of 11 Old 02-06-2015, 11:25 PM
Knuckelhead
R.I.P. Knuckelhead
The most common failure on the TJ fuel pump is failure to maintain pressure when the engine has been at rest for a period of time. The multiple key on, key off and key on to repressurise the fuel rail comes into to play.
More information from the OP would be needed... IMO
post #11 of 11 Old 02-10-2015, 09:11 AM
Pentara
Pentara's Avatar
Any chance you recently did anything with your speedometer gear? If for example you removed it and replaced it, or put it back in without the proper alignment, the teeth could be slipping at higher speeds. I'm not an expert but I believe this is an input into your transmission and could cause wierd shifting or other problems.
Pentara is offline
engine , engine performance , fuel pump , power loss , spark plug
