Engine hoist tub removal - JeepForum.com
post #1 of 7 Old 06-17-2021, 06:13 PM Thread Starter
JeepinCanada
JeepinCanada's Avatar
Hello everyone!
I'm nearing the point in my travels where I can finally start to lift the TJ tub off of the frame. I have an engine hoist or cherry picker as I've seen some call it and I was thinking about how to actually pick the tub up with it.
As far as I can tell and from what I've read around the internet the best way to do this is either from the back using the seat mounting nutserts or from the side again using the seat mounting nutserts.
Does anyone know:
1. Which seat mounting nutserts to use
2. The thread size of those nutserts
3. What type of hardware to use in those nutserts
4. How to rig it all together for the most stable and safe set up.
Thanks!
JeepinCanada is offline
post #2 of 7 Old 06-17-2021, 07:53 PM
jeep_boy02
1934 CJ7
Honestly the easiest would be to have your neighbor, friend, brother, whom ever help you. I've removed a few tubs just me and another guy.
If a helper isn't an option then I'd rig up an over head pulley. Doesn't need to be a chain Houston or anything exotic, a regular single or even better double pulley and rope hung from the rafters or a tree limb. Like a block and tackle I think is what they are technically termed.
Sent from my SM-A015A using Tapatalk
80 CJ7-304/T176/D300 HEI hdrs-WT D30/D44 4.56s, lockright/spool-SOA YJs W/RE AAL-35 MTRs beadlocks
jeep_boy02 is offline
post #3 of 7 Old 06-18-2021, 07:12 PM Thread Starter
JeepinCanada
Thanks for the reply. Unfortunately those aren't really an option for me at the moment and I already have the engine hoist in my garage ready to go so I would prefer to use that.
Still looking for answers if anyone has some insight.
Thanks.
post #4 of 7 Old 06-18-2021, 10:10 PM
jeep_boy02
1934 CJ7
3 pieces of 2x4 made into an "I"... capital "i"
Place top and bottom of "I" across left to right to body. One under the triangular door gussets, and the other under the cowl. Then the 3rd piece will span those two front to back in the center.
Then you can screw and eye bolt through the center of that. May have to play around with finding exactly where the center of gravity lies but I think it would be pretty close to center between those two cross boards.
I'd say lift it from the side
Guess I coulda used an "H"....
post #5 of 7 Old 06-20-2021, 06:55 PM
TJ4Jim
Thanks.
This was real simple and worked like a charm, four 1/2" threaded rod into the overhead truss with two 4 x 4"s thru the roll cage. I tacked 6" pieces of 1/4" steel rod to a 1/2" nut to act as a wing nut.
If you come to a fork in the road take it.
TJ4Jim is offline
post #6 of 7 Old 06-20-2021, 07:20 PM
dbbd1
dbbd1's Avatar
A+ for innovation!
The opinions of worthless people, are worthless.
The only problem that you have with anyone in this world, is what you expect of them.
Society is no match for a stupid person.
"Life Is tough but it is tougher when you are stupid"
-John Wayne
dbbd1 is offline
post #7 of 7 Old 06-22-2021, 10:29 AM
Subfixer
I used a tow strap looped through the front cowl braces and up through the shifter hole.
Rear strap to stabilize the tub.
Most of the weight is in the front of the tub.
Subfixer is offline
