LinkBack | Thread Tools |
Effect of disconnecting front/rear sway bars
My jeep is for off road use only, so I disconnected my front sway bar to see if I notice a difference....and it makes a huge difference when going over rocky terrain. Quite amazing actually, as the bumps were hardly noticeable. My question is: what effect would disconnecting the rear sway bar have? Similar or none? Just want some opinions before i give it a whirl
Sponsored Links | |||
Administrator
LEAVE THE REAR ANTISWAYBAR CONNECTED. It's ok to disco all antiswaybars on leaf spring vehicles but not coil spring suspensions like the TJ has. Leaf springs are stable in all directions except up-down, coil springs are not stable in any direction. Not being connected at all reduces stability and it can actually mean a flop on an extremely off-camber trail where being connected on at least the rear would prevent it.
Also, disconnecting the rear antiswaybar does not increase its usable articulation/flex. Which is why it's easy to find quick disconnects for the front antiswaybar but few, if any anymore, make them for the rear antiswaybar since they don't help. In fact discos in the rear can hurt.
The best way to go is to leave the rear connected and replace the front antiswaybar with a Currie Antirock which is a more flexible form of an antiswaybar. That eliminates the need to disconnect before going offroad and it also balances the f/r suspension so they work together instead of fighting each other.
Not to mention most high-end rock-crawling TJs are running either a front Antirock and a rear antiswaybar, or both front and rear Antirocks.
John Currie won the entire ARCA rock crawling series and was overall champion after developing the Antirocks. His Fireant TJ had Antirock antiswaybars front and rear and both were connected during competition.
I was there and shot these photos...
For what it's worth, on the street, the rear sway bar does nothing.
I've had the rears removed on my lifted TJ and stock ZJ (Well, more like 'broken' off - stupid bolts!) and I never got around to putting them back on. I don't notice any real difference in handling. When the front on my ZJ broke a link as well, then I felt it.
Off road, I am not sure how it would feel to have BOTH disconnected. As mentioned, performance on the rear is not really improved with it off; the front is a huge difference, however.
Administrator
Originally Posted by Maverickxeo
View Post
Originally Posted by Jerry Bransford
View Post
Do you have any other recommendations for making an extremely rocky road more comfortable to drive on? Again, the jeep is not so much a fun thing for us but a necessity for where we live, and doesnt go on paved roads.
Thanks
Administrator
What air pressure is in your tires? What shocks are you running? Since your tires are already deflated, the other part that can cause a stiff ride are your shocks. What brand and model shocks are installed?
View Post
I have bilstein 5100 shocks i purchased back in 2008...do you have any recommendations? Thanks again for your help.
Administrator
Originally Posted by ebp123
View Post
Not sure the air pressure in the tires, I just let air out enough to where all of them have the same 'bubble?' when on the ground.
A much better riding shock that is not expensive is the gas-charged Rancho RS5000x which should not be confused with the older harsh/stiff riding hydraulic RS5000. I used to run them and you could haul-a$$ on some pretty rough roads with them, I liked them a lot.
View Post
Oh yeah, those Bilstein 5100 shocks are known for being stiff riding. A well-known Jeep builder once opined that you should only run Bilstein 5100 shocks if you want to know if the half-dollar piece you just rolled over was heads or tales lol.
Administrator
I'm confident they'll make a very noticeable improvement on your ride. No need to jack your Jeep up or remove the tires to replace the shocks, all that can be done on the ground.
Sway bars control movent. They reduce body roll. Two sway bars working together help keep the body centered between the articulating axles. The added balance, predicability and stability gained from both front and rear sway bars doesn't matter until it matters. An "off-road only Jeep" will only benefit from a pair of tuned and balanced sway bars.
The factory front is too stiff to be very useful off-road. A softer, tunable sway bar like the Antirock makes a world of difference. The factory rear will easily support 12" travel shocks.
2003 Rubicon
I broke the rear sway bar link (actually the bolt that holds it together)
When the front was connected I didn't notice it too bad but my tire were still aired down so I was driving like a grandpa anyway.
Once aired up and driving normal it was noticeable but not as much as having the front disconnected but having both disconnected ? Holly flip farting crazy cow it was BAD!!
You do pick up articulation. But like mentioned above at some point is does you no good ESP if you do not have lockers.
I replaced the rear bolt in the links but keep it a little loose. I like having the little extra movement. I live "out there" and drive nothing but curvy country roads, county dirt roads or forestry roads or off roading. I rarely go faster than 60-65mph.
For me, going from Super Swampers to AT tires had a greater affect on how my Jeep drove an handled than about anything other than having both sway bars disconnected.
01TJ33sWarn,ARBs F&R,bellyup,4.0,4.56s,5spd
99 XJ33sWinch,Electric locker up front,4.56s,4.0Auto
Previous Thread
Next Thread
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Posting Rules | |
