E-brake cable for disk brake kit - JeepForum.com
post #1 of 9 Old 07-26-2010, 03:30 PM Thread Starter
Jetscuh
O rly?
1968 FSJ Wagoneer
I currently have Teraflex's disk brake kit on my Jeep. However, that kit did not include an E-brake. I can't seem to find one made by them either.
Who/where should I get an E-brake cable from?
Jetscuh is offline
post #2 of 9 Old 07-26-2010, 03:34 PM
thirdeye
thirdeye's Avatar
I just ordered some replacements because mine were bent. Here's the part number
Passenger - 52008362
Driver - 52008363
I went to a few auto stores and none of them had it in stock or could even find it. I found a pair somewhere online shipped for like $55
2004 4.0L I6 TJ BUILD:
1997 2.4L I4 TJ BUILD:
https://www.jeepforum.com/forum/f22/thirdeyes-second-tj-1816002/
thirdeye is offline
post #3 of 9 Old 07-26-2010, 04:20 PM Thread Starter
Jetscuh
O rly?
1968 FSJ Wagoneer
And that would work with my set up?
Jetscuh is offline
post #4 of 9 Old 07-26-2010, 06:58 PM
thirdeye
thirdeye's Avatar
Well, they're stock replacement cables. Maybe I misunderstood, do your current stock cables not work with the Teraflex kit?
thirdeye is offline
post #5 of 9 Old 07-27-2010, 04:15 AM Thread Starter
Jetscuh
O rly?
1968 FSJ Wagoneer
I don't believe that my stock cables will work.
Teraflex does make e-brake cables but it's about $100.00 for the two of them. Quite expensive.
However, I found their disk brake conversion kit to resemble the brakes off of a Grand Cherokee...they're very close, if not the same. Would e-brake cables from a Grand Cherokee just be what they're using?
Jetscuh is offline
post #6 of 9 Old 07-27-2010, 05:36 AM
80 CHOPPER
Try (inlinetube.com) they can make any cable you need in any size.
DRAGON
80 CHOPPER is offline
post #7 of 9 Old 07-27-2010, 07:21 AM
conrasm
conrasm's Avatar
I don't know if KJ (liberty) e-brake cables would work with the teraflex kit, but they work with explorer rear discs on an XJ, no mods needed at either end. I know the equalizer side from the handle is the same on my 94 XJ and 00 TJ. There are a couple different part numbers, but this is the one that works...
52128510AG
They will be long though and need a loop to take up the slack.
Shawn
'00 TJ Sahara (RC 4" LA kit)
'06 Grand Cherokee Limited
'07 Ram 1500 quad cab
conrasm is offline
post #8 of 9 Old 07-27-2010, 08:10 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Parking brake cables from a TJ with rear discs and Grand Cherokee of the ZJ era with rear discs will also work.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #9 of 9 Old 07-27-2010, 09:55 AM Thread Starter
Jetscuh
O rly?
1968 FSJ Wagoneer
Ok, I thought so. Thank you.
Jetscuh is offline
parking brake cable
2001 TJ Drum brake to Disk brake questions javelin390 TJ Wrangler Technical Forum 0 03-16-2010 05:42 PM
Disk Brake converstion 97MilitaryTJ TJ Wrangler Technical Forum 0 11-27-2007 12:24 AM
Disk brake conversion Rmen TJ Wrangler Technical Forum 2 08-14-2006 07:44 AM
RE Rear Brake Line and E-Brake Cable Questions? Jeep4Rox TJ Wrangler Technical Forum 1 01-12-2006 03:42 PM
ZJ to TJ disk brake writeup ugrider21 TJ Wrangler Technical Forum 2 03-04-2005 06:48 AM
