DV8 Shifter Knob - JeepForum.com
post #1 of 4 Old 06-12-2021, 08:05 PM Thread Starter
Charleston82CJ7
1982 CJ7
DV8 Shifter Knob
I have a CJ, and the PO put one of these shift knobs on and I can’t get it off. It says the knob is for a TJ, so hopefully someone here knows how it attaches. I didn’t know if there is a lock nut, or the top cap comes off, but I’m starting to suspect the PO glued/epoxied the knob on the T-4 shift lever
https://www.amazon.com/DV8-Offroad-T...66314143&psc=1.
Charleston82CJ7 is offline
post #2 of 4 Old 06-13-2021, 06:58 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
The stock TJ shift knob has a nut under the shift pattern cover. Most aftermarket shift knobs simply screw on without using the stock nut.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
2003' Rubicon/Zone 4.25" combo lift with Rancho RS5000X shocks/ Zone hydro shocks/5.13 gears/35" Mickey Thompson MTZ P3 tires/Black Magic brakes. Jeep #17 & 19.
TheBoogieman is offline
post #3 of 4 Old 06-13-2021, 04:44 PM
Jo3Gee
Jo3Gee's Avatar
DV8 Shifter Knob
Pull the rubber ‘tread’ off, there might be a set screw under it.
Jo3Gee is offline
post #4 of 4 Old 06-13-2021, 05:05 PM
19GCTrailhawk
19GCTrailhawk's Avatar
2019 WK
The lower tapered section unscrews from the knob section. I believe that's where you'll find the set screws.
2019 Grand Cherokee Trailhawk 5.7
Grand Cherokee Owner since 1994
19GCTrailhawk is offline
