Durango Steering Gear in a Late Model TJ (03-06) - JeepForum.com
post #1 of 59 Old 07-14-2009, 11:50 AM Thread Starter
pachary
After reading a few posts from MrBlaine, I decided to jump into the Durango box for my 05 LJ.
1. Remove stock box.
2. Remove steering shaft, drill plastic pin from both sides, reinstall collapsed shaft.
3. Use 1" hole saw to cut front box mount sleeve out of frame.
4. Bolt durango box using 2 back bolts and determine if sleeve will fit or if frame needs to be clearanced. I needed to grind about 1/8" from the front lower corner of hole.
5. Bolt the box back in with 3 stock bolts, tack weld the sleeve. Remove box and weld up sleeve.
6. Use a stock 97-02 TJ pressure hose, reinstall box (shaft, 3 bolts, hoses).
7. Install Pitman arm (I used a stock flat 80s Waggy arm for my D44)
8. Bleed system
My biggest problems were getting my stock return line to route in there. I will probably go with a universal clamp in return soon.
The other challenge was getting the boxex in and out by myself. They are a bit heavy and it would help to have an extra set of hands to hold it while getting bolts started.
Whole thing took about 3 hours this morning, again by myself.
Now I will be ready for high volume pump and hydro assist this winter! You actually can't even tell anything was done with the skid in place.
Paul
2005 TJ Unlimited/I6-M6/Rubi 4:1 Tcase/4.5RESF/1.25JKS BL-1BMML/37"SSRs/WarnM8000/Besttop TireCarrier/Waggy D44/ FR-RR DetroitD44/Cobra Remote CB/custom F&R Bumpers/JeeperMan Skids/York OBA/Rokmen TummyTuck/TNT 3" Fenders and Rear Corners/AA SYE- Carolina Drivelines CV Shaft
pachary is offline
post #2 of 59 Old 07-14-2009, 12:09 PM
Jebussaves0
Jebussaves0's Avatar
Any pictures?
2002 Jeep Wrangler Sahara | 4.0L 5spd D44/D30 3.73s | Hurst Shifter |
| Hummer-Style CAI | 1" Rusty's BL/MML | AA TC Shifter Bracket | 2" BB | JKS Quicker Discos | 33x10.50R15 BFG KM2s | Alpine CDA-9886 HU | OTRATTW Switch Panel | G.P.F. Rear Bumper | Metalcloak Overline Fenders
M416 Trailer | In Progress
Jebussaves0 is offline
post #3 of 59 Old 07-14-2009, 01:29 PM Thread Starter
pachary
Um, no. And on your jeep it is a direct bolt in.
There really isn't much to see.
pachary is offline
post #4 of 59 Old 07-14-2009, 01:32 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
8. Bleed system
Paul
Good job. It's just not that hard to do, is it?
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #5 of 59 Old 07-14-2009, 01:51 PM
Jebussaves0
Um, I realize that It was really for other people's benefit
post #6 of 59 Old 07-14-2009, 02:00 PM
uvalax236
x2!!! I want to do this on my 06. Pics of the hack-and-weld job?
06 Solar Yellow AT
uvalax236 is offline
post #7 of 59 Old 07-14-2009, 03:04 PM Thread Starter
pachary
OK, when I take it apart (not promising when), I will get pics. But I promise it really is as easy as it sounds. As long as you can drill and weld, the rest is unbolting and bolting stuff back in. I didn't take the pics as I was doing it because it was that simple (and I didn't have my camera monkey handy).
Heck it is so cramped in there, it is hard to see what is what looking with your eyes and a flashlight, especially since my winch cables and hydraulic hose for OBA go by there also.
pachary is offline
post #8 of 59 Old 07-14-2009, 04:03 PM Thread Starter
pachary
OK here's the pics of what you can see
Side view of the 3 bolts after install. The relocated one is furthest left.
Durango box with Waggy pitman arm:
Relocated Sleeve
pachary is offline
post #9 of 59 Old 08-11-2009, 05:10 PM
UnlimitedNJ
Good job. I did the same thing on my LJ 2 weeks ago. I used a Chevy Astro pitman arm, works great with my over the knuckle steering and stock track bar location.
Why don't you go back to your home on whore island?!
UnlimitedNJ is offline
post #10 of 59 Old 10-31-2012, 12:55 PM
DanZ51
DanZ51's Avatar
Originally Posted by UnlimitedNJ View Post
Good job.
THERE'S THE MONEY SHOT, I WAS LOOKING FOR
Niicce
You didn't plate the inside of the rail too, did you?
"I will always be an American Soldier"
DanZ51 is offline
post #11 of 59 Old 10-31-2012, 01:13 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Niicce
I don't plate them. I just make some oversize weld washers out of 3/16's and put them over the bolt sleeve. Mine are typically clipped on one side to butt up against the front tube.
The hole size is a healthy clearanced 7/8".
I am Savvy
mrblaine is offline
post #12 of 59 Old 07-01-2013, 01:30 PM
2k2wranglerx
To drag this back up. did you have to modify your steering shaft or your high pressure line?
93 yj. 355 chevy, heads, cam, intake, etc. 35's, bumpers, winch, lights, and a killer stereo.
2k2wranglerx is offline
post #13 of 59 Old 07-01-2013, 01:36 PM
Benderff
Benderff's Avatar
Looks like that is covered in the first post, lines #2, and #6.
Benderff is offline
post #14 of 59 Old 07-01-2013, 01:44 PM
2k2wranglerx
DOH. ya i'm a ******* lol
post #15 of 59 Old 07-01-2013, 01:49 PM
2k2wranglerx
Does this change the position of the pitman arm? ie: will the one that's fine on my 03 box be fine on the older box?
Thanks!
durango steering. 99 durango 00 tj pitman arm slafferty TJ Wrangler Technical Forum 0 09-05-2009 02:28 PM
HP30 from late model YJ I8AHUMR YJ Wrangler Technical Forum 1 08-19-2009 07:55 PM
New Durango Steering Gear Box Leaking cvd TJ Wrangler Technical Forum 15 06-13-2008 10:42 AM
Late model Manifolds on early model Wooders TJ Wrangler Technical Forum 12 07-11-2006 07:57 AM
Late model mods Jeep Affecionado TJ Wrangler Technical Forum 6 03-28-2002 03:36 PM
