Durango Alternator Swap with pictures! - Page 11 - JeepForum.com
 1Likes
post #151 of 152 Old 05-17-2016, 11:27 AM
SvtLdr
Originally Posted by D0T-C0M View Post
How many wires on the alternator plug on your 97? I didn't specifically research that but seems to me I read something about the voltage regulator being internal to the alternator on the older models. Regardless of the plug in or if the regulator is in the alternator, All that would be requires is to install an external voltage regulator which is pretty simple and get a new plug-in if its different. Its doable just a little more work. I am pretty sure the alternator bolts in but don't quote me on it
DOT-COM, there are 5 total connections on the back of the early TJ alternators (I have a '98). 2 field terminals, a ground terminal, a harness holdown nut and the wire to the battery. The early alternators are also externally regulated by the PCM.
I picked up a 136A alternator from a Grand Cherokee (same connections as mine) to replace my original 90A. In your opinion is the original 6AWG wire and 10AWG fusible link sufficient for 136A output?
SvtLdr is offline
post #152 of 152 Old 05-17-2016, 10:17 PM
Knuckelhead
R.I.P. Knuckelhead
Knuckelhead's Avatar
IIRC all TJ's use the voltage regulator in the PCM.
I installed the same 136 amp alternator in my 2000 Sport.
I'm using the OEM 10 AWG fusible link without any issues. Its been in use for 10+ years... HTH
Knuckelhead is offline
dodge , durango , alternator , swap , tj , wrangler
Durango 160 amp alternator to 06 TJ swap N8Doggz TJ Wrangler Technical Forum 56 06-22-2011 03:20 PM
02 Durango 5.9L Alternator in a 01'? TJamz TJ Wrangler Technical Forum 2 07-20-2010 08:13 AM
TJ/Durango steering box swap DBraceM20 TJ Wrangler Technical Forum 5 11-25-2006 01:59 PM
Durango Alternator Thug Nasty TJ Wrangler Technical Forum 5 09-13-2006 06:00 PM
durango steering box swap jeepinkeller TJ Wrangler Technical Forum 0 05-21-2004 03:30 PM
