Dudes, we all have these problems...right??? (Axle off center, body imperfections) - JeepForum.com
post #1 of 14 Old 05-18-2009, 11:38 PM Thread Starter
TJWillys
Hey Guys,
1) I have a 2005 TJ Willys Edition with 33" x 12.5" tires. When I look at my rear passenger side tire it sticks out about a 1/4 of an inch more than all the others. I checked all of the usuals (i.e. spacers, rim offset, axel possition), and everything seems okay. Anybody else with larger tires see this variance as well? I guessing it has something to do with the configuration of the 4 wheel drive.
2) Also, why are there 4 circular indents shaped like an "L" below my tail lights on each side? At first I thought is was shotty body work, but then I saw them on a few other TJ's as well.
Thanks for your time!
TJWillys is offline
post #2 of 14 Old 05-18-2009, 11:49 PM
TJDaveX
TJDaveX's Avatar
A lift with stock track bars will pull your axles over to one side. I am assuming you have a lift with 33's. Fill out your profile.
TJDaveX is offline
post #3 of 14 Old 05-18-2009, 11:55 PM
chouser06
^^^ Exactly what he said... Mine did the same thing.
2001 White TJ Sahara--3inch suspension lift--1.25inch BL with 1inch MML--Rustys HD tie rod--35x12.50 Baja Claws--Locker front/rear--Black rock sliders--Black cragar soft 8's--Black tube fenders--More to come!!!!
chouser06 is offline
post #4 of 14 Old 05-19-2009, 12:01 AM
wozz
Originally Posted by TJWillys View Post
Hey Guys,
factory spot welds? I'd have to go look at mine but I bet that's what they are.
wozz is offline
post #5 of 14 Old 05-19-2009, 12:08 AM Thread Starter
TJWillys
Just filled out my profile. I got a 1" BB. Thanks for the info.
TJWillys is offline
post #6 of 14 Old 05-19-2009, 12:16 AM
chouser06
Hey Guys,
I dont think I have those spots under my tail lights? Of if I do, I havent noticed them? How can you see the indents on the driver side? Isnt your license plate bracket there?
post #7 of 14 Old 05-19-2009, 01:52 AM
BP88
Maybe the previous owner had corner guards on it before?
BP88 is offline
post #8 of 14 Old 05-19-2009, 02:05 AM Thread Starter
TJWillys
Okay...looking at the plates, there should be three vertical indentations lined up just below the right side of the plate...all about the size of a hole punch. You can't really see them at first. I only noticed them when looking closely to the paint. Anybody else?
TJWillys is offline
post #9 of 14 Old 05-19-2009, 02:10 AM
chouser06
Id go outside and look but its 3:00am and Im in my night clothes (aka sheets and blankets) Plus its kinda chilly out tonight.
post #10 of 14 Old 05-19-2009, 02:11 AM Thread Starter
TJWillys
Do you know if that will in any way negatively effect the pressure put on the wheel bolts? How about uneven tire wear?
BTW, To the great state of Washington. Used to live in Walla x2 myself.
TJWillys is offline
post #11 of 14 Old 05-19-2009, 02:26 AM
TJDaveX
TJDaveX's Avatar
As far as wheel bolts and tire pressure, I have no idea. I have read on this forum that having your axles a bit off center does not hurt anything on the Jeep if driven that way. It is more if it bugs you or not. It bugged me, so I have an adjustable front track bar and a rear track bar relocation bracket on mine to center things up.
Washington State is a great place. So much to do. Mountains, lakes, forest, desert, ocean, everything. I have lived all over, but I like it here.
Could use a better Governor though!
TJDaveX is offline
post #12 of 14 Old 05-19-2009, 02:43 AM Thread Starter
TJWillys
Agreed with the Governor.
I'm a detail guy so I guess I might have to go your route on centering my axels. Thanks for the parts list!
TJWillys is offline
post #13 of 14 Old 05-23-2009, 10:09 PM Thread Starter
TJWillys
Indentations anybody?
TJWillys is offline
post #14 of 14 Old 05-24-2009, 02:20 AM
WillysEdition04
WillysEdition04's Avatar
They're just the spot welds from the welding robots. Some colors (like our Moss Green) show it more than others, but they're all there. I've had them on all 3 TJ's I've owned now. (and all were some color green)
04 TJ Willys Edition 41MB-04TJ ...SOLD
08 JK Unlimited
WillysEdition04 is offline
1" body lift and center of gravity brinoff YJ Wrangler Technical Forum 5 06-14-2009 11:31 PM
Body Mount/Body Lift problems need help! muddy8jeep8 TJ Wrangler Technical Forum 0 02-03-2009 03:53 PM
Center Body Bumper Mount Problem? docbud TJ Wrangler Technical Forum 4 04-23-2007 07:23 PM
Yo dudes and dudetts Wind_Danzer TJ Wrangler Technical Forum 2 09-10-2004 10:20 PM
Body off center? Falcor TJ Wrangler Technical Forum 7 09-08-2004 03:06 PM
