Drum Brakes - JeepForum.com
post #1 of 5 Old 07-01-2010, 10:41 AM Thread Starter
Mudbug1979
Drum Brakes
Anyone know of a write up for removing and reinstalling drum brakes. I am going to change out my axle shafts this weekend, but I have never messed with drum brakes before. Kind of sad considering how long I have been owning my TJ
Mudbug1979 is offline
post #2 of 5 Old 07-01-2010, 11:07 AM
rkymtn05
rkymtn05's Avatar
Jeep Rear Drum Brake Remove - Install and Adjust
Good luck with it, I did my drums a couple weeks ago. It's not as hard as you think, just take your time and do one wheel at a time to use the other for visual reference.
rkymtn05 is offline
post #3 of 5 Old 07-01-2010, 11:14 AM Thread Starter
Mudbug1979
Do I have to remove the brakes to change the axle shafts?
post #4 of 5 Old 07-02-2010, 08:04 AM
rkymtn05
rkymtn05's Avatar
I think all you have to remove is the drum and maybe the shoes. Check out stu-olson's website, his site will most likely give you the info your looking for.
rkymtn05 is offline
post #5 of 5 Old 07-02-2010, 04:07 PM
wushaw
Rockin jeep
wushaw's Avatar
No, just pull tire & drum.
wushaw is offline
drum brakes , removing , write-up , tj , wrangler
Replace Rear D44 Drum Brakes with Newer Factory D44 Disc Brakes? NIB-98TJ TJ Wrangler Technical Forum 18 12-30-2009 07:55 PM
Drum brakes - #$%&*!! bryris YJ Wrangler Technical Forum 20 05-06-2009 05:29 PM
*u*k Drum Brakes I need help. Chillpill109 YJ Wrangler Technical Forum 8 11-07-2008 11:16 PM
Converting rear drum brakes to disc brakes Urb4nTr0ll YJ Wrangler Technical Forum 4 05-15-2008 06:16 PM
Help with Drum Brakes... WickedYJ YJ Wrangler Technical Forum 11 12-25-2005 03:21 PM
