Door Wont Open - JeepForum.com
post #1 of 5 Old 03-11-2010, 09:43 PM Thread Starter
flip124
Door Wont Open
The inside pull handle on my TJ has been broken for awhile but I just kept pulling from the outside and it worked fine. Well now it won't open from the outside. Anything I can do short of cutting the door panel up?
<99 Sahara - 8.8, HP30, 35's> <98 ZJ - IRO 3.5, 31's> <93 XJ> <95 Chevy K1500 - Mild 350 (Cam, vortec heads, edelbrock intake, true dual flowmasters)>
flip124 is offline
post #2 of 5 Old 03-11-2010, 09:53 PM
Alkaline
Alkaline's Avatar
What kind of doors do you have? And instead of cutting it, try removing the hinge and seeing if you can pull it open enough to access the panel screws.
☠ ʎɐqə ɯoɹɟ pɹɐoqʎəʞ ɐ ʎnq ı əɯıʇ ʇsɐl əɥʇ sı sıɥʇ ☠
'98 TJ (toy), '91 XJ Briarwood(DD)
Alkaline is offline
post #3 of 5 Old 03-11-2010, 10:54 PM Thread Starter
flip124
Stock doors. I haven't driven it all winter and just assumed they were frozen shut. Not the case right now. I'll give it a shot.
flip124 is offline
post #4 of 5 Old 03-12-2010, 12:56 AM
gotmudnj
gotmudnj's Avatar
get in on the passanger side lol...jk i agree with pulling hinge off and see if you can access the door panel screws...
**** Happens.....
~~GOT MUD CENTRAL NEW JERSEY 4x4 ~~
gotmudnj is offline
post #5 of 5 Old 03-12-2010, 07:39 AM
rainmn
2014 JK Wrangler
Wrangler door panels can be removed with the door closed - I've had to do it.
You can get to all 5 screws easily, and it just takes some finesse to pop off the panel and work it up and off with the door closed.
rainmn is offline
Door wont open WranglerMangler TJ Wrangler Technical Forum 8 09-25-2009 10:25 AM
Door wont open from inside? wmeyer116 TJ Wrangler Technical Forum 7 01-30-2009 08:09 AM
Door wont open... VICTIM_OF_PAIN TJ Wrangler Technical Forum 18 08-01-2007 12:35 PM
inside door handle wont open door alecmcmahon YJ Wrangler Technical Forum 2 07-30-2006 06:39 PM
door wont open Blackjackbender TJ Wrangler Technical Forum 1 06-22-2006 10:07 AM
