JeepForum.com (https://www.jeepforum.com/forum/)
-   TJ Wrangler Technical Forum (https://www.jeepforum.com/forum/f9/)
-   -   Dome Light LED Swap Write-Up (https://www.jeepforum.com/forum/f9/dome-light-led-swap-write-up-1764585/)
BABrax 11-06-2013 01:28 PM
This is a write-up on how to swap the OEM dome light with an LED light. Couldn't find a write up on here when i looked so i made one myself. Very easy, but for visual help here's what you do.
Step One
Remove the dome light cover. Its just a plastic cover that is latched on. Mine had a gap in it already, so i just popped it off with my fingers. If yours is more difficult there are notches for a flat head screwdriver on the front and back.
http://server.myspace-shack.com/d21/img703625779.jpg
http://server.myspace-shack.com/d21/img703723085.jpg
Step Two (And final step)
Slide the old bulb out, slide your new LED in. Very simple. Then just pop the light over back on and its good to go!
http://server.myspace-shack.com/d21/img703459169.jpg
http://server.myspace-shack.com/d21/img703399829.jpg
Very Simple, and makes the world of difference.
Some more info:
Dome Light LED Size-LED 921/T13
Best place to buy from is superbrightleds.com they have a cross referencing guide that tells you all the bulbs that will fit under that size. just click the size on the left http://www.superbrightleds.com/bulb_cross.php
Very easy and i hope it helps! You can also pick bulbs with different colors to do a color change on the inside, just follow the same steps!
Before and after pics later tonight!
vtx531 11-06-2013 08:40 PM
Nice write-up but is it really bright enough for you? I think most people go with an LED panel in there.
rbkelley89 11-06-2013 09:45 PM
light pics
BABrax 11-06-2013 10:23 PM
Hard to tell by the pictures but i like it! Not blinding light, but its definitely brighter. No over doing it, but definitely makes a difference
BABrax 11-06-2013 10:29 PM
Before/After pics
http://server.myspace-shack.com/d21/img7050.jpg
http://server.myspace-shack.com/d21/img7051.jpg
Here is a pic of light off compared to light off in the front seat
http://server.myspace-shack.com/d21/img7054.jpg
http://server.myspace-shack.com/d21/img7053.jpg
Pics are hard to tell, but i am beyond satisfied with the results. Not crazy bright to where you cant see with it on, and provides great light for basically the entire jeep
TexasTJ 11-06-2013 10:54 PM
I think a single bulb would probably suffice, I used a panel of LEDs when I changed mine like you said though. Also did the courtesy lights in LED.
http://farm3.staticflickr.com/2812/9...9ea87cc124.jpg
http://farm6.staticflickr.com/5482/9...9b565268f4.jpg
The time now is 01:51 AM.
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
