Doing some Whining.. - JeepForum.com
 1Likes
  • 1 Post By rikkards
post #1 of 7 Old 10-23-2019, 03:39 AM Thread Starter
Tumturbo
Started hearing some whining about a week ago. Sounds like road (tire) noise but only happens when letting off the accelerator or in neutral while moving. It got worse fast! I'm thinking throw out bearing but want your opinion first.
97 tj 2.5l 5speed 280,000 mi.
Thank you!
Tumturbo is offline
post #2 of 7 Old 10-23-2019, 04:17 AM
rikkards
rikkards's Avatar
Rear pinion bearing?
Mall_Terrain_TJ likes this.
Machete don't tweet
- Machete
rikkards is offline
post #3 of 7 Old 10-23-2019, 09:39 AM
hdbiker1
2009 JK Wrangler
How about rear wheel bearings?
hdbiker1 is offline
post #4 of 7 Old 10-23-2019, 12:36 PM
Mall_Terrain_TJ
Rear pinion. Either bearing, chipped teeth, or... low on oil (I've seen it twice now)
Sent from my SM-N960U1 using Tapatalk
Mall_Terrain_TJ is offline
post #5 of 7 Old 10-23-2019, 01:05 PM
mukluk
mukluk's Avatar
Remove the rear driveshaft and drive the Jeep using the front axle. If the noise goes away when doing this, that'd point pretty solid toward the rear axle being the cause.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #6 of 7 Old 10-25-2019, 02:00 PM
Jeepsr4me
U joints can do this also. Removing the rear drive shaft and shifting jeep into 4x4 and drive.
If the noise goes away it could be the shaft or diff.
Check fluid in the rear and transfer case..
I seen the front shaft make a noise and it was only noticeable rolling with engine off. I get up to speed on a quite road with no others around for a bit. Turn engine off and let it roll. The things you can hear with no running engine...
Jeepsr4me is offline
post #7 of 7 Old 10-28-2019, 05:22 PM Thread Starter
Tumturbo
Turned out to be all of the above mall_terrain_tj. Thanks all for your input
Tumturbo is offline
