Does Your Tie Rod Do This? ;) - JeepForum.com
post #1 of 203 Old 05-08-2010, 03:44 PM Thread Starter
mrblaine
Wizard of Brakes
mrblaine's Avatar
And then look like this when you put the tires back on the ground?
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #2 of 203 Old 05-08-2010, 03:53 PM
Humboldt
Humboldt's Avatar
Very cool.
Humboldt is offline
post #3 of 203 Old 05-08-2010, 04:02 PM
Ben_321
judging by the tie rod on the ground im assuming you replaced your tie-rod? what one is that? or is it homemade?
i just put the RC heavy duty on mine, looks beasty
Ben_321 is offline
post #4 of 203 Old 05-08-2010, 04:02 PM
BoarderX47
What tierod is that Blaine? I am running the JKS after my stock one decided it wanted to pull a stump out of the ground that I was stuck on..... I would be surprised if the JKS tie rod would do that
BoarderX47 is offline
post #5 of 203 Old 05-08-2010, 04:04 PM
jdragger
What rod ends did you use?
jdragger is offline
post #6 of 203 Old 05-08-2010, 04:10 PM
jforse
jforse's Avatar
Looks like he made it.
jforse is offline
post #7 of 203 Old 05-08-2010, 04:19 PM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
could it be the currie steering setup? yes, yes it is.
Mail crawling.
MisfitSeven is offline
post #8 of 203 Old 05-08-2010, 04:23 PM
99TJtommy
very cool..
99TJtommy is offline
post #9 of 203 Old 05-08-2010, 04:33 PM
JCWJEEP
2010 JK Wrangler
Ha! I highly doubt mine would. very cool.
JC Whitney Jeep Team
JCWJEEP is offline
post #10 of 203 Old 05-08-2010, 05:17 PM
biffgnar
biffgnar's Avatar
Didn't Blaine say a few months ago he was making a limited run of tie-rods that would bend and then return to original straight shape? I thought he even took orders from some people on here. I assume that is what this is.
biffgnar is offline
post #11 of 203 Old 05-08-2010, 05:27 PM
miguelitojeep97
I'm thinking this is currie.
but... try smacking that tie rod with the entire weight of the vehicle on a rock, and then lets see it go back to its original shape
1997 TJ 4.0 5 spd. rock track 4:1, 3.5 inch Rock Krawler 5 inch stretch long arm, 35 inch MTRs, Warn 9k, D44/30 locked with 4:88s, Vanco BIG BRAKES!!and more...
miguelitojeep97 is offline
post #12 of 203 Old 05-08-2010, 05:34 PM
JCWJEEP
2010 JK Wrangler
Look at how clean the underside of that Jeep is. It's disgusting how bad living in the rust belt is.
JCWJEEP is offline
post #13 of 203 Old 05-08-2010, 06:03 PM Thread Starter
mrblaine
Wizard of Brakes
mrblaine's Avatar
You should know better. Go to our website, look at the video of Gerald dropping the whole front of his rig on the tie rod. He does that at least 5 times per run and his tie rod that's been on there almost a year, is made the same way.
I am Savvy
mrblaine is offline
post #14 of 203 Old 05-08-2010, 06:05 PM Thread Starter
mrblaine
Wizard of Brakes
mrblaine's Avatar
I did say that and this is the first one. Heat treated 4340 to about 56-58 HRC.
A lot of spring, huge amounts of strength and nearly indestructible.
I am Savvy
mrblaine is offline
post #15 of 203 Old 05-08-2010, 06:07 PM
Rockpile
Rockpile's Avatar
1994 ZJ
Well Blaine, my next mod will be steering
Rockpile is offline
