Does this D44 shaft need to be replaced? Leaky- Grooved seal surface - pic - JeepForum.com
post #1 of 4 Old 09-10-2018, 08:12 AM Thread Starter
vtx531
Looks like I have three options: (I already have the new bearing/seal)
1. Free - Take my chances and replace bearing/seal- run it with the groove.
2. $50 - Speedi sleeve. Bandaid fix?
3. $105 - New G2 replacement shaft
Anyone have experience with the above options?
I am leaning toward the new shaft.
vtx531 is offline
post #2 of 4 Old 09-11-2018, 07:24 AM
NashvilleTJ
I miss the snow...
NashvilleTJ's Avatar
For the $55 difference between the speedi sleeve and the shaft, I'd go with the shaft. Either way, I don't think you can run it the way it is without leaks.
Jeff
Build Thread:
Swing Away / Swing Down Tire Carrier:
NashvilleTJ is offline
post #3 of 4 Old 09-11-2018, 07:41 AM
2jhanna
Or maybe check classifieds here and/or local clubs to see if you can find a "take off" shaft where someone upgraded.
I am multi-talented, I can talk and piss you off at the same time.
jhanna
denton county, tx
2jhanna is offline
post #4 of 4 Old 09-11-2018, 04:35 PM
1968
Like Nashville stated, for the price differential, buy a new shaft and be done with it. It absolutely will leak if installed the way it is.
1968 is offline
