Do I have to use a Daimler Chrysler home brew? - JeepForum.com
post #1 of 4 Old 03-14-2003, 06:37 PM Thread Starter
TJSilverSport02
TJSilverSport02's Avatar
Starting to get some supplies together to do the SYE install and went to Autozone for some of them. The Jeep manual says to use ATF-4, man at the ‘Zone says he doesn’t have it and I gotta get it from stealership, it’s their special formula. WTH!, is he correct?
ATF-3 is a no-no?
Thanks for any info.
Stroked/RELA/ARBs/etc,etc...
TJSilverSport02 is offline
post #2 of 4 Old 03-14-2003, 07:01 PM
K9JEEP
Registered Abuser
K9JEEP's Avatar
I've been hearing that any ATF will work. But I'm not sure if that's correct.
K9Jeep
K9JEEP is offline
post #3 of 4 Old 03-14-2003, 08:41 PM
igofshn
Locked @ both ends
igofshn's Avatar
Any quality ATF will work in the t-case.
2007, 4 door, powered by a minivan engine, locked and riding on 35's.
igofshn is offline
post #4 of 4 Old 03-15-2003, 02:20 PM
bcompton
bcompton's Avatar
While you are at it, why not put in some good quality synthetic like Mobil 1 ATF? It meets all standards, and since you don't change the fluid very often it might just be worth the extra few bucks.....
bcompton is offline
C02 OBA Home Brew LSU_TJ TJ Wrangler Technical Forum 47 06-15-2009 08:44 PM
Home brew schizm99 YJ Wrangler Technical Forum 1 07-20-2007 12:54 PM
Daimler Chrysler checkup zolf TJ Wrangler Technical Forum 1 03-23-2005 06:36 AM
Soft Top Probs. Daimler-Chrysler sucks M1Shooter TJ Wrangler Technical Forum 13 08-04-2004 05:38 AM
Dear Daimler Chrysler... Weelspin TJ Wrangler Technical Forum 0 09-25-2002 06:56 PM
