Disable the SKIM (Sentry Key Immobilizer Module) - Page 11 - JeepForum.com
post #151 of 266 Old 12-20-2011, 03:54 PM
gamble
So what happens if I just unplug my SKIM and put in a new one? Why does it have to be reprogramed? It just looks for the chip right?
98 ZJ -4.0L
Lots of welders and cnc table
gamble is offline
post #152 of 266 Old 01-08-2012, 09:53 AM
ski boy
SKIM Problems
HI All,
Hope this thread is still active!
Have had problem with SKIM for past 2 years..back then, someone told we to "toggle" passenger door lock switch 6 times on/off and this would reset the SKIM, it has worked great for the past two years, now can't get my 99 JGC to stay running!! How /where is the SKIM module so I can try unplugging it to see if this will solve? Also, if the chip in the Jeep key is the issue how would getting a generic cut key and using Jeep key near the ignition switch resolve the issue, as some have suggested??
Need help, asap, as Jeep is stranded 3 hours from home & i need to get it started, thanks!!
ski boy is offline
post #153 of 266 Old 01-08-2012, 10:10 AM
gamble
Skim is that black piece under the steering column that has a black ring that goes over where the key goes in.
98 ZJ -4.0L
gamble is offline
post #154 of 266 Old 01-08-2012, 10:25 AM
Keith_C
Here's a thread with lots of pictures...
https://www.jeepforum.com/forum/f140/...nstall-742054/
Keith_C is offline
post #155 of 266 Old 01-20-2012, 05:04 PM
RockScar
So has anyone tried the allcomputerresources.com SKIM delete? This is the last major hurdle for me for my CJ's engine swap...
RockScar is offline
post #156 of 266 Old 01-20-2012, 06:44 PM
krazzyboy_1
B&G can turn it off.
DOHC 2.4L Turbo.
krazzyboy_1 is offline
post #157 of 266 Old 01-21-2012, 07:18 AM
ski boy
So what's B & G?
ski boy is offline
post #158 of 266 Old 01-21-2012, 01:32 PM
RockScar
Originally Posted by ski boy View Post
so what's b & g?
x2
RockScar is offline
post #159 of 266 Old 01-21-2012, 01:36 PM
RockScar
So what's B & G?
I'm guessing these guys?
bgperformancepcm.com
RockScar is offline
post #160 of 266 Old 01-21-2012, 02:10 PM
krazzyboy_1
Yes that's the one. If you are looking to reprogram your jeep's PCM their are very few options, B&G is one of the first to come up on any search.
DOHC 2.4L Turbo.
post #161 of 266 Old 01-23-2012, 12:19 AM
gamble
If I could afford the downtime I would try it.
98 ZJ -4.0L
gamble is offline
post #162 of 266 Old 01-25-2012, 03:41 PM
RockScar
Well, I'll be using one or the other for mine. I have a '00 TJ motor, pcm, and skim, but no key or vin . So unless I find the diamond pcm in the junkyard rough, I'll report back with how the skim removal went.
RockScar is offline
post #163 of 266 Old 02-21-2012, 08:21 AM
gamble
Try it yet?
98 ZJ -4.0L
gamble is offline
post #164 of 266 Old 02-22-2012, 04:17 PM
RockScar
Quoting my own post....
I happened to find a pcm on ebay, but subsequent calls to the allcomputer people left me frustrated with their customer service. The first time I called, they quoted me at $120, no problem. By the time I was ready to send it, I called again and they seemed annoyed with answering my questions. I was told they don't take customers' pcms to mod, but eventually after badgering them they agreed. But, like I said I found one on ebay, so I guess someone else will have to be the guinea pig! Good luck!
RockScar is offline
post #165 of 266 Old 03-13-2012, 07:29 AM
gamble
autocomputerexchange warranty sucks. they want me to send mine in so they can test it then they will send it out. Meaning I would be without a truck for over a week. **** this place
98 ZJ -4.0L
gamble is offline
Currently Active Users Viewing This Thread: 8 (0 members and 8 guests)
Ravelco VS. Sentry Key Immobilizer System Nerv TJ Wrangler Technical Forum 20 12-29-2011 06:18 PM
SKIM "Sentry Key Immobilizer Module" install RedRubiconLJ TJ Wrangler Technical Forum 45 12-13-2011 09:25 AM
SKIM (Sentry Key Install) Success! ACDJeeper TJ Wrangler Technical Forum 17 09-11-2011 05:15 AM
Sentry Key™ engine immobilizer [can a thief bypass this easily?] Nerv TJ Wrangler Technical Forum 2 01-02-2009 10:25 AM
Sneaky Immobilizer. / disable TJ gas gauge Panici TJ Wrangler Technical Forum 3 02-13-2008 12:46 AM
